Mhuffy The Traveller.
36inter
Re: Mhuffy The Traveller.
Post by 36inter »
Perhaps one like my old one from 1970
InimiaD
Post by InimiaD »
Hmmm, choices, choices.
All will be revealed in the distant (judging by my last visit to the sprayers) future. :roll:
Some pics taken back in early September.
,,,,,,,,, and a few pics of what little progress has been done since then. These pics were taken mid December. Really flying ahead now. Yeah, right. :cry:
Excuse the "donkey" subframe. All the underside, wheel arches and engine bay done and that i'm afraid is that.
georgek
Post by georgek »
Nice to see more paint going on, you've achieved a lot!
SteveG
Post by SteveG »
Thats 'Van' Tastic! :lol:
InimiaD
Post by InimiaD »
Thank you gents.
Not much progress on the paint side of things. :cry:
I swung by the sprayshop a couple of weeks ago and as i suspected nothing extra had been done to the shell.
However, I was promised that the shell would be back in the spray shop at the end of this month.
In the meantime I've been getting together a motley collection of spare engine bits and pieces ready to assemble and fit into a sacrificial front subframe (wet).
Once fitted I can start knocking up some extra engine mounts as per the 1100 type mounts.
I found an Austin / Morris 1100 haynes book and it looks as if the front nearside engine mount bracketry is bolted to the leading edge of the subframe, so that will save ruining my newly powder coated donor subframe.
The sacrificial subby.
When I get the chance and the weather warms up a bit I'll crack on with it. ;)
InimiaD
Post by InimiaD »
Managed to bolt all the "motley" bits together.
As you can see, there isn't much room to fabricate a new rear mount.
The block needs to be leaned backwards by about 20mm which makes the rear mount even tighter than it looks. Got some head scratching to do. :roll:
There's enough room on the front though to make a decent support bracket.
36inter
Post by 36inter »
I've used that arrangement before on my sons car, should be a standard fitment for all mini engines, the engine just does not move, brilliant.
A bit of fabrication, burn a few rods and bingo best fix for engine wobble. Ever.
Pete
36inter
Post by 36inter »
When you fabricate the plates for the rubber mounting blocks to sit against, instead of a hole cut a slot from the top so the mounting drops down into it, back and front, its much easier to get the engine in and out
Pete
InimiaD
Post by InimiaD »
36inter wrote:When you fabricate the plates for the rubber mounting blocks to sit against, instead of a hole cut a slot from the top so the mounting drops down into it, back and front, its much easier to get the engine in and out
Pete
Good call Pete. If the mounting plate is of a heavy enough gauge and once it's bolted up the engine won't be going anywhere.
I could make the rear mount and possibly the front mount fixed which would save a lot of grief further down the line.
Tidy.
JC T ONE
Post by JC T ONE »
InimiaD wrote:
You got mail ;)
InimiaD
Post by InimiaD »
Jens, did you get my email.?
Made a start on the front mount. I basically made it up as I went along using Pete's advice to make a slot in the mounting plate. The new rubber engine mounts have a bolt and a locating pin on them which I decided to utilise. Should help in keeping the mount fixed in place..
After a few card templates were cut out I finally went for this design which gave as much support to the mounting plate as possible while leaving access to get a spanner in.
36inter
Post by 36inter »
Thats a nice bit of fabrication, as long as you have a nice thick flat washer under the nut thats going nowhere.
Pete
JC T ONE
Post by JC T ONE »
Hi InimiaD,
nope :?: no mail ?
The one you made, look very good 8-)
Is your thread up to date now ? = body in paintshop, and you doing frames / engine, while waiting, for it to be finished.
InimiaD
Post by InimiaD »
Thanks guys.
@Jens. Yes, the build is up to date. Still no progress with the paint though. :roll:
The front subby is back from the powder coaters.
Looks good enough to eat my dinner off. Welded up some of the seams and stiffened up the front tie bar mounts and added an extra bracket for a lower engine steady.
I may not need it now though.
JC T ONE
Post by JC T ONE »
Hi InimiaD,
sorry to hear about your long wait for the paint. hope its worth it ?
Mine was at the paintshop April 18, and finished June 30.
But it was not painted under neath, nor was it painted inside.
That subframe looks nice 8-) so now you have 2 ;)
Have you done the rear bracket yet ?
Tim
Post by Tim »
I love that engine steady, now I'm wondering why the factory didn't do it like that?
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
InimiaD
Post by InimiaD »
Thank you Tim.
It's not quite the finished article. I need to add some stiffeners and a couple of captive nuts.
Jens, The Husky was out on the weekend to saw some logs up and I didn't get round to starting the rear mount.
Thanks for the pics of your Janspeed mounts. My design for the rear could now be changed. ;)
Progress before last weekend.
JC T ONE
Post by JC T ONE »
Happy to help ;) you will be thrilled about the finished article, the car drives SOO much smoother with these mounts 8-)
As Tim said " why didnt BMC/BL do this? " ? it would have been so much easier for a factory.
They already had the stuff on the shelves.
Tim
Post by Tim »
It also seems obvious to support the engine within the subframe, rather than running the second steady to the bulkhead, which just looks like an afterthought to me.
Tim
1955 BSA C11G
1969 Triumph TR6R
IAIN
Post by IAIN »
Tim wrote:I love that engine steady, now I'm wondering why the factory didn't do it like that?
Tim
looking at the engine bracket and thinking, as Tim said, why the factory wouldn't have done it like that.
My only thought looking at the pictures is may be it would be better with a little web either side of the bracket to support the height against sideways movement, which could cause the subframe or welds to crack.
May be worth a thought at this stage ? If you hadn't already.
Nice idea though.
