1964 Rust project
Frogeye61
1964 Rust project
Post by Frogeye61 »
I've actually been working on this thing for a while, since August 2016. It's been on the other Mini forum but I figured that the Mk1 crowd needs to see this too.
It started when the son (Tim) of a guy (Peter) at my office bought this very rusted car with a "new inspection" out of Jylland (about 200 km from Copenhagen where we live). He drove the car for a year or more but rust was a very big problem. After making arrangements with me, because I have several old British cars, the two stripped the Mini down and brought me the shell.
Frogeye61
Re: 1964 Rust project
Post by Frogeye61 »
A few pics of the shell when it arrived at my backyard garage.
I suppose you get the idea of what needs replacing here.
Normally one would just rebody, but a Mk1 body isn't easy to obtain for reasonable price, and we didn't want to go with a later body. So the decision to rebuild was made.
Frogeye61
Post by Frogeye61 »
On 14 November a lot of stuff came from M-machine including things like these.
Frogeye61
Post by Frogeye61 »
The first thing was to brace the body inside. We hoped it would be good enough to keep everything in line.
The front wing was about to fall off so I hacked it off just to see how bad everything was behind the A panel.
The sunroof necessitated that we change the roof panel also.
Frogeye61
Post by Frogeye61 »
By the end of November we had gotten the main floor removed.
Good luck with what looks like a major project. I look forward to following your progress.
2311Jethro
Post by 2311Jethro »
I suddenly feel a lot less daunted by my project! Have fun, it looks like you will be building a real car from just the shadow of the old one. Good stuff.
Knitting for the modern man.
Frogeye61
Post by Frogeye61 »
The front floor / foot panel was covered on both sides with an external plate to hold in the rust. This maybe to show the inspection man that there wasn't any rust on the outside. :)
ImageIMG_20161129_190022s by frogeye61, on Flickr
ImageIMG_20161129_210334s by frogeye61, on Flickr
Additionally, the seat belts were mounted to the bins with WOOD. :roll:
ImageIMG_20161206_185542s by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Peter, his son Tim, and I work generally on this "vehicle" every Tuesday evening after work starting around 17:30 until around 22:00. Peter and I are very enthusiastic while Tim, who is also very interested in doing the project would also like to learn to weld. This is certainly a good place to start :)
Around early December we positioned the main floor with brackets, though not sure of the exact placement due to the new boot floor not being in place. None of the fixed, known positioning points are available except the bottom of the seat back. The rear seat back will be kept and repaired. This might seem odd, but we needed some way to position the boot floor.
ImageIMG_20161206_205326s by frogeye61, on Flickr
ImageIMG_20161213_185444 by frogeye61, on Flickr
ImageIMG_20161213_211541 by frogeye61, on Flickr
ImageIMG_20161213_211550 by frogeye61, on Flickr
Braces were added to hold the stiffener frame to the main floor. The rest of the body at this point is held up only by these struts.
Image2016-12-18_05-01-46 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Just before Christmas we had a rather productive day working on the boot floor.
First, off with the rear fenders. (wings for you Brit chaps)
ImageIMG_20161220_181336 by frogeye61, on Flickr
The boot floor is still held by the back panel and seat back.
ImageIMG_20161220_182334 by frogeye61, on Flickr
Once those are cut free the entire boot floor and inner fenders comes out as one unit.
ImageIMG_20161220_183531 by frogeye61, on Flickr
The shell seems a bit empty at the back
ImageIMG_20161220_190421 by frogeye61, on Flickr
The new floor and inner fenders pretty much fit into place with only the seat back to position it. This isn't enough so everything is left to "float" until fixed points can be obtained.
ImageIMG_20161220_195854 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
The first workday after Christmas Peter was not available so I worked on my own Mini, straightening the A post left over from it's field racer background. The following workdays were used to do the rear panel...
ImageIMG_20170111_194643 by frogeye61, on Flickr
ImageIMG_20170111_194953 by frogeye61, on Flickr
ImageIMG_20170116_171958 by frogeye61, on Flickr
ImageIMG_20170118_074225 by frogeye61, on Flickr
ImageIMG_20170118_074247 by frogeye61, on Flickr
and test fit of the rear fenders.
ImageIMG_20170118_174502 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Around the rear side windows is a lovely mess of rust. Since this part is not available from M-machine, I just welded all the holes using small pieces of plate where necessary. This also includes the window mounting flange. The replacement fender doesn't contain this flange so a suitable base is maintained to weld the fender to.
ImageIMG_20170124_222816 by frogeye61, on Flickr
ImageIMG_20170125_211216 by frogeye61, on Flickr
The rear fenders are fitted by careful trimming to butt-weld directly to the existing mounting points.
ImageIMG_20170129_172840 by frogeye61, on Flickr
ImageIMG_20170129_172850 by frogeye61, on Flickr
Peter wasn't quite as accurate with the angle grinder, but it worked just fine.
ImageIMG_20170129_172900 by frogeye61, on Flickr
The other side was also given this procedure and by the end of January the back of the exterior sheet metal was nearly ready.
ImageIMG_20170131_201940 by frogeye61, on Flickr
Bloody hell, that is one massive project. I thought it looked 'reasonable' in the first few pics as well.
Still, this is a really interesting thread as I may (with luck :? ) be embarking on a similar project later in the year.
Looking forward to seeing more developments here :)
Frogeye61
Post by Frogeye61 »
Thanks, Remember that this is a consolidation of a build I have been working on since August. It isn't really much further along yet, well maybe a bit.
Frogeye61
Post by Frogeye61 »
Fitting up the rear panels: Rear panel placed as it should be along with fenders and roof as a test fit.
ImageIMG_20170131_215641 by frogeye61, on Flickr
Since I don't yet have the spot welder, the rear panel is pulled off to drill for plug welds.
ImageIMG_20170221_194702 by frogeye61, on Flickr
Then all re-aligned.
ImageIMG_20170221_195727 by frogeye61, on Flickr
Then a whole mass of plug welds
ImageIMG_20170221_215459 by frogeye61, on Flickr
ImageIMG_20170221_215920 by frogeye61, on Flickr
Welding the corners
ImageIMG_20170223_190600 by frogeye61, on Flickr
And then tacking the fender front edge to the original fender edge
ImageIMG_20170221_215951 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
I saw these pictures on a forum somewhere:
And then I passed by the trash trailer:
So I gathered the other pieces:
and I made this: I know it's a complete waste of time while I have all the other projects going, but I just had to.
Don't get the wrong idea that I cut a perfectly good Mk1 bonnet in half. It was completely trashed with rust and a big bend right in the middle, covered with no less than a cm of plastic padding.
ImageIMG_20170223_184028 by frogeye61, on Flickr
I may however use that bumper mount strip for my own Mk1
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
With luck???? :lol:
Andrew1967 wrote:Bloody hell, that is one massive project. I thought it looked 'reasonable' in the first few pics as well.
Frogeye61
Post by Frogeye61 »
About this time Tim got to remove spot welds from the windshield frame
ImageIMG_20170124_213534 by frogeye61, on Flickr
ImageIMG_20170124_222909 by frogeye61, on Flickr
And Peter got to cut the top frame. Holes in the roof are for better access
ImageIMG_20170307_182416 by frogeye61, on Flickr
ImageIMG_20170307_182501 by frogeye61, on Flickr
Then off with the frame
ImageIMG_20170307_191522 by frogeye61, on Flickr
ImageIMG_20170308_071338 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
The rear fenders are finished welding as everything seemed to fit just right.
ImageIMG_20170305_171820 by frogeye61, on Flickr
Spot welds around the rear inner fenders
ImageIMG_20170304_104942 by frogeye61, on Flickr
The firewall is then cleaned up and the sides of the top dash piece.
ImageIMG_20170315_081058 by frogeye61, on Flickr
Welding is needed where someone put a fuse box through the firewall and hacked the rotisserie opening
ImageIMG_20170315_081105 by frogeye61, on Flickr
The edge of both A posts were rotten so re-establishing the edge at the exact same dimensions as original.
ImageIMG_20170316_190223 by frogeye61, on Flickr
ImageIMG_20170317_070944 by frogeye61, on Flickr
On 22 March we took a short (ahem) trip to see Georg Mikkelsen of ÅKM Racing. We bought a 1275 A+ engine and box for my own 64 Mini, as well as Cooper S disk brake kit, and a double skin boot lid in perfect condition. The engine was a gift from Peter as he is using my garage.
ImageIMG_20170318_153827r by frogeye61, on Flickr
Gerog is known for designing this:
ImageIMG_20170318_135018 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Inside the windshield frame, A posts, and the top of the firewall which would be behind the scuttle panel were painted with epoxy primer. Shame the factory didn't think of this.
ImageIMG_20170321_201034 by frogeye61, on Flickr
ImageIMG_20170321_201037 by frogeye61, on Flickr
ImageIMG_20170321_201048 by frogeye61, on Flickr
I also welded the fuse box hole and fixed the rotisserie hole edges
ImageIMG_20170322_155805 by frogeye61, on Flickr
Finishing the weld comes later
