1964 Rust project
Frogeye61
Re: 1964 Rust project
Post by Frogeye61 »
Thanks, good point. I will use spacers both around the edge and between door and closing edges while determining fit of the A panel.
Frogeye61
Post by Frogeye61 »
Well, I fixed up the inner A-post panel...
ImageIMG_20170612_195741s by frogeye61, on Flickr
cleaned up the edge flanges, cleaned up the inner fender where it meets the flanges, and spot welded the left inner fender in place. Then plug welded where I couldn't reach with the spot welder, and CO2 welded finishing edges.
ImageIMG_20170613_211539s by frogeye61, on Flickr
The top is ready for the scuttle double plate
ImageIMG_20170613_211658s by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Well, this Tuesday we took care of a number of smaller items.
Scuttle closing panel, though a bit hard to see in the photos. Used the spot welder on the front edge and full weld against the inner fender.
ImageIMG_20170620_192136s by
ImageIMG_20170621_073814s by frogeye61, on Flickr
Repaired the rust behind the right side fender brace
ImageIMG_20170620_194111s by frogeye61, on Flickr
I must say it still needs a bit of clean-up but thoroughly cleaned inside and rust protected. The brace itself also got some lovely new numbers. (not pictured)
ImageIMG_20170621_073822s by frogeye61, on Flickr
The rear subframe braces were welded in place. They aren't too bad, but need a bit of finishing.
ImageIMG_20170621_073915s by frogeye61, on Flickr
Under-door panel is trimmed to fit the surrounding panels.
ImageIMG_20170621_073946s by frogeye61, on Flickr
And the A post rear face is to be positioned correctly with relation to the door.
ImageIMG_20170621_073957s by frogeye61, on Flickr
Productive evening, though I would like things to go a bit faster.
Van13
Post by Van13 »
Well done for tackling this mini it's nice to see talented people at work
Frogeye61
Post by Frogeye61 »
Lots of fun last weekend.
The 64 Mini: I've been working on fitting the left side door, adjusting and placing the door step, door pillar, and inner A-panel in relation to the front wing, inner fender and front panel. Everything got clamped or tack welded together with the door bolted to hinges and bolted to the inner A-panel with spacers to replace the outer A-panel. The door seal strip was also partially installed to hold distance between the door and body.
Door is held vertically with a single C-clamp and in towards the body with another. A couple iterations of door step panel placement with tack welds and I found just the right place. Door fits well all around. A panel fits well, and front wing fits against inner fender, A-panel, front grille surround, and of course the bonnet.
ImageIMG_20170624_161616 by frogeye61, on Flickr
The fit here is absoutely NOT good.
ImageIMG_20170624_163108 by frogeye61, on Flickr
Much better.
ImageIMG_20170624_172952 by frogeye61, on Flickr
ImageIMG_20170624_173003 by frogeye61, on Flickr
ImageIMG_20170624_173125 by frogeye61, on Flickr
ImageIMG_20170624_163516 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Well, after the door fit nicely last weekend, we used our usual Tuesday evening "boy's night" and after very much re-checking tack-welded the inner A-panel in place. We checked the door for motion...
ImageIMG_20170627_183928 by frogeye61, on Flickr
and since everything was ok, I went ahead and full welded the A-panel. There were several pieces that needed some small patches but it seemed ok in the end. We then gave a thorough covering with waxoil (cavity wax, hulerumsbeskyttlese)...
ImageIMG_20170627_203315 by frogeye61, on Flickr
and mounted the outer A-panel with spot welds along the exposed edges and along the foot step and A post cover. (not completely finished in this photo)
ImageIMG_20170627_211939 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
While I was doing the left door opening and A-panel, Tim was working on the right inner wing. Front floor patch is done but not yet the edges of the A-post vertical panel or dash shelf. The inner wing fits well for now.
ImageIMG_20170628_074501 by frogeye61, on Flickr
Regarding fit of the left wing, it seems quite good, as in it can be placed directly on top of the existing surrounding metal and has good gap with the bonnet, A-panel, and front panel.
ImageIMG_20170628_074555 by frogeye61, on Flickr
ImageIMG_20170628_074547 by frogeye61, on Flickr
Excellent work here and I'll say again that I'll be referring to this thread many times when I start my S project.
Frogeye61
Post by Frogeye61 »
Due to domestic requirements and duties, I only got a bit to work on the Mini. I managed to repair all the flanges which attach the right front inner wing to the body. Most had been badly rusted and cut to remove the rust. One, the parcel shelf had been accidentally cut in half. It's a good thing he didn't cut it completely off. I butt welded new flanges on all places which were missing, and the bottom inner panel of the A-post was also missing. This piece was otherwise spot welded to the inner panel of the floor section. All parts ground smooth awaiting Tuesday when we will install the inner wing.
ImageIMG_20170702_175023 by frogeye61, on Flickr
ImageIMG_20170703_074905 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Ja, I also found time to make a template for inner wing protectors. Very necessary in Denmark, especially with the odd MK1 design of hinge mount reinforcements being directly exposed to road dirt.
First a cardboard template
ImageIMG_20170629_170624 by frogeye61, on Flickr
Then another better cardboard template (not shown) then an aluminium template made of 0.3 mm aluminium.
ImageIMG_20170629_175235 by frogeye61, on Flickr
The final will be of 1.5 mm aluminium. The edges will be cut back a bit so I can mount a sealing rubber edge. Mounting will be onto the shock flange mount bolts, bolts on the front panel, and I will weld small flanges onto the lower door hinge reinforcement and lower inner wing.
It fits under the wing
ImageIMG_20170629_175141 by frogeye61, on Flickr
and radiator air will have to exit between the inner wing protector and the front valence.
ImageIMG_20170629_175148 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Tuesday evening as usual; re-positioned the right side inner wing and after much checking and alignment spot welded the sections I could and then plug welded the sections I couldn't reach with the spot welder.
ImageIMG_20170704_195609 by frogeye61, on Flickr
ImageIMG_20170704_195623 by frogeye61, on Flickr
Welded on the inner wing's replacement top flange and all internal welding
ImageIMG_20170705_074812 by frogeye61, on Flickr
We tested temporary fitting of both wings, both before and after fitting the inner wings and front panel. A couple spots on the front panel to hold it in place and it might eventually look like these snaps.
ImageIMG_20170705_074753 by frogeye61, on Flickr
ImageIMG_20170704_204551 by frogeye61, on Flickr
Right side A-panel, door and foot step panel still need fitting.
ImageIMG_20170704_204610 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
Last night's endeavors were less fruitful than expected. Sorry, no pictures as it would be very difficult to express the dilemma.
The exact culprit is elusive at this time, however symptoms are that the right side door, while spaced correctly to the right rear wing, and bolted to the A-panel via the two hinges, comes about 10 mm short of the front wing. The wing which itself is properly in line with the scuttle (one-piece together with windscreen surround), and also aligns properly with the front edge of the bonnet, and also with the front panel, whilst the bonnet is also nicely aligned with the scuttle.
Measurements done by Tim did not reveal the source of any discrepancy so I am now forced to measure again myself, and possibly to make some "unorthodox" solutions.
It may not seem like much done for the last week, but it does take quite a bit of time to properly align the panels. And because I didn't work on the Mini last weekend. I instead test drove my Frogeye. First time on the road since the early 80's (I've owned it since 73). For that you get a few pictures (and a short film).
ImageIMG_20170708_174452 by frogeye61, on Flickr
ImageIMG_20170708_145559 by frogeye61, on Flickr
ImageIMG_20170708_151844 by frogeye61, on Flickr
ImageVID_20170708_145208 by frogeye61, on Flickr
Nick W
Post by Nick W »
doors can vary in size from car to car, I had a nos door that was 10mm shorter than the other side door, I was told it was a Welsh door :?: :?: :?: :lol:
if everything seems straight ,just mig a small strip on the front edge ,refit the door and then adjust the gap with a sanding disk.
Nick
Up North in Sheffield
Callum
Post by Callum »
I did what Nick suggested on my doors. It was quite a big gap so chipped the flux off a welding rod and migged that down the edge
Frogeye61
Post by Frogeye61 »
Well, I found a solution to the non-fitting components. I re-measured everything and found no fault with tim's measurements. Everything was ok. Possibly the only real problem is the scuttle flange could be a bit too long, therefore interfering with the front wing.
By keeping the door in the correct position with respect to the window frame and clearance to the rear wing, hinges as far forward as possible by slight filing on the mounting holes, A-panel as far forward as possible which also gave good clearance to the door and aligned with the windshield a-post, and with the front wing as far back as possible by slight forming of the contact point with the scuttle... I know that was long...
I have added a small sliver (8mm) to the length of the A-panel.
ImageIMG_20170712_082037 by frogeye61, on Flickr
It now fits like a charm.
ImageIMG_20170712_203225 by frogeye61, on Flickr
This was absolutely not possible before. The seam was like a snake. It is now straight.
ImageIMG_20170712_203140 by frogeye61, on Flickr
I have of course modified the outer A-panel to match. The bottom edge was deficient by about 5 mm so was beat into alignment.
ImageIMG_20170713_200854 by frogeye61, on Flickr
the two edges fit like a charm. (yes there are two panels in the photo)
ImageIMG_20170713_200851 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
We finally got the A-panel mounted, aligned and welded in place. The door fits fine and despite the appearance in this photo, it really does fit at the bottom.
ImageIMG_20170715_160303 by frogeye61, on Flickr
ImageIMG_20170715_160334 by frogeye61, on Flickr
The yellow appearance is a reflection of something behind me. The inner A-panel is covered in rust protection.
ImageIMG_20170718_201749 by frogeye61, on Flickr
ImageIMG_20170718_201805 by frogeye61, on Flickr
Welds inside the wing are ground reasonably smooth.
ImageIMG_20170718_201755 by frogeye61, on Flickr
The rusty metal at the bottom of the right rear door surround is removed in favour of using the maximum metal available from a new door step panel. The support cage is removed from this corner and the car body hasn't yet collapsed.
ImageIMG_20170718_201818 by frogeye61, on Flickr
Problem is that the replacement door step is shaped wrongly from new. Easily repaired.
ImageIMG_20170718_205542 by frogeye61, on Flickr
Though no picture, I beat the corners into the correct shape and it looks superb. It fits the door very well with good door gap all along. Tonight I will weld this piece in place.
Fantastic work!
Just to be a downer for one moment, have you tried the doors with the door seals fitted?
Always a good bet when so much has been repaired.
Frogeye61
Post by Frogeye61 »
mk1 wrote:Fantastic work!
Yes, actually I have, and this was due to "Mike - llmikeyj" mentioning it on Jun 08.
llmikeyj wrote:Just a thought, have you refitted your door seals when testing the door fit? Mine were fine until I put the rubbers in. Nightmare thereafter...
Mike
The rubbers can in any case be seen in this image:
9330FN
Post by 9330FN »
Another point and it will come much later but remember to put in the sound deadening glued on to the underside of the roof between the roof and headlining otherwise the Mini will boom. I have a Mk3 that was restored and the noise was horrendos and I went right through the car until one of the lads at Minimine said 'oh that'll be the roof lining' - and it was. :roll:
I have done that too. It's like riding round in a kettle drum!
I have also had the sound deadening pads sold by Newton drop off, so best to make sure they are stuck on very well.
