1964 Rust project
Frogeye61
Re: 1964 Rust project
Post by Frogeye61 »
By the last week in March it had been installed.
It's a Mk3 frame so it didn't quite fit right at the top (taller doors) and two of the wiper holes had to be filled.
ImageIMG_20170325_101735 by frogeye61, on Flickr
But in general the fit was quite fine. I used a spot welder so it wouldn't deform things. The firewall repair can also be seen here.
ImageIMG_20170326_140206 by frogeye61, on Flickr
rich@minispares.com
Post by rich@minispares.com »
some panel action going on there!
rolesyboy wrote:With luck???? :lol:
I can understand your reaction :lol: :lol:
Frogeye61
Post by Frogeye61 »
It became very difficult to mount the rear subframe. This due to not-exact alignment of the heel board mounting fixtures. We suspected something was very wrong with the new floor pan so we pulled it out. The floor pan had never been welded to any part of the body, merely clamped to the boot floor, so out it came.
ImageIMG_20170404_200908 by frogeye61, on Flickr
Then the subframe was mounted to the heelboard
ImageIMG_20170404_201328 by frogeye61, on Flickr
and the whole assembly positioned
ImageIMG_20170404_202232 by frogeye61, on Flickr
by the rear subframe to boot floor bolts
ImageIMG_20170405_071153 by frogeye61, on Flickr
and the front subframe to footboard bolts.
ImageIMG_20170404_210736 by frogeye61, on Flickr
ImageIMG_20170411_183500 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
the observant browser will notice the roof missing in the last photo. This is because immediately after welding the windscreen surround on, and therefore stiffening up the upper shell, we simply cut around the edges of the roof, separating it from the remainder of the window surrounds. It was already loosened from both the front and rear window panels so only the sides needed cutting loose.
ImageIMG_20170411_185536 by frogeye61, on Flickr
ImageIMG_20170411_185541 by frogeye61, on Flickr
The old roof edge, the one that was roll-welded, was simply cut back as far as possible toward the rain gutter.
ImageIMG_20170411_185556 by frogeye61, on Flickr
and polished to produce a completely clean metal surface
ImageIMG_20170411_190254 by frogeye61, on Flickr
The drip rails were removed for later installation of reproduction parts.
ImageIMG_20170411_202425 by frogeye61, on Flickr
Repairs were of course performed on the considerably rusty rain gutters, though surprisingly the original roof edge was ok. All four corners needed larger repairs.
Frogeye61
Post by Frogeye61 »
Mounting of the new roof is tested, and determined to not fit well. Actually the roof fits, but the rain gutter needed to be nudged out enough to allow the new roof to come in.
ImageIMG_20170425_193315 by frogeye61, on Flickr
After considerable "weaseling" it fit in.
ImageIMG_20170501_154903 by frogeye61, on Flickr
The roof is removed and edges cleaned
ImageIMG_20170501_174045 by frogeye61, on Flickr
Inside the body structure is cleaned and painted with epoxy...
ImageIMG_20170502_071942 by frogeye61, on Flickr
as is the hidden part of the roof section.
ImageIMG_20170502_071951 by frogeye61, on Flickr
Then the roof is clamped in place.
ImageIMG_20170502_185602 by frogeye61, on Flickr
This was NOT just an afternoon's work, rather a couple weeks, though as usual working only Tuesday evenings and a bit on the weekends.
Frogeye61
Post by Frogeye61 »
The roof was then, ok most of the roof, was spot welded in place. Turned out that quite a bit of the sides, under the drip rail, was not completely clean. But front and back were just fine. 2mm thick front and rear, 3mm thick on sides due to the old roof edges.
ImageIMG_20170502_201240 by frogeye61, on Flickr
Video:
ImageVID_20170502_202535 by frogeye61, on Flickr
ImageIMG_20170502_201259 by frogeye61, on Flickr
2311Jethro
Post by 2311Jethro »
WOW and I envy your clamp collection. Nice work.
Knitting for the modern man.
rich@minispares.com
2311Jethro wrote:WOW and I envy your clamp collection. Nice work.
I find that you can never, ever have enough welding clamps!
Craig
Post by Craig »
Thats a great job you lads are doing !!! :D
Not much of the original shell left , must have been VERY Rusty !!
Craig
Frogeye61
Post by Frogeye61 »
We didn't do much on the Mini this weekend. Received some parts from Mini Spares and ordered some other parts for my own 64 Mini, mostly for the engine, and got my Sprite running well - until I found a very large oil leak coming from the back of the engine.
Today is Tuesday, and as usual we will be working on Peter's 64 Mini tonight. Until then, a video of the Sprite.
ImageVID_20170508_200922 by frogeye61, on Flickr
rich@minispares.com
ive got a fibreglass front for a frog if you need one!
Frogeye61
Post by Frogeye61 »
rich@minispares.com wrote:ive got a fibreglass front for a frog if you need one!
Of course one would ask the question of the quality of the front.
I have both the very rusty metal front, and a fiberglass I got when I was at Gaydon in 08 from Jayne at frogeyespares. Unfortunately it didn't fit very well and I did a lot of modifications to get it to the condition it's in now which includes reshaping both side panels and all internal structure taken from the original bonnet. The headlight mounting surfaces still point up too far. I would at one point like to purchase all replacement inner structure and a front lower valence for rebuilding the original (which isn't original, but the 3rd bonnet this car has had).
ImageIMG_20161008_144939 by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
I didn't mean to hijack my own thread. This is about the Mini.
Last night we finished up nearly all of the roof spot welds. Just missing an area where the original gutter is gone but the old roof edge is still there. I will put a replacement segment in and weld it up. Tim isn't confident enough to do this properly.
Meanwhile Peter did a very respectable job of removing the right side inner fender
ImageIMG_20170509_213556 by frogeye61, on Flickr
ImageIMG_20170509_213611 by frogeye61, on Flickr
ImageIMG_20170509_213711 by frogeye61, on Flickr
Some work will be needed on the A-post before the new can be installed. To facilitate installation of the front inner fenders, a replacement segment of the top rear was previously welded into the windshield surround when the surround was installed. We will just clip off the top of the inner fender and weld to the replacement instead of the normal method of removing the scuttle end. I hope this makes sense.
Frogeye61
Post by Frogeye61 »
It seems like it's been forever since last post. House work, friend's confirmation, My own Mini and Frogeye, so we managed to get a bit done last night on Peter's Mini (and a '53 motorcycle sidecar).
Peter carefully cut all the spotwelds for the left inner fender, removed it and cleaned up all the edges readying it for the new part. Now all it needs is to install the entire front, and A-panels, and front door jams. OK, I suppose it needs the front subframe installed to be sure everything fits. But maybe then we can begin to weld... of course after we fit everything with mole grips and triple check it all.
ImageIMG_20170516_201009s by frogeye61, on Flickr
ImageIMG_20170516_200957s by frogeye61, on Flickr
ImageIMG_20170516_213224s by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
I was unfortunately not able to work my usual Tuesday evening last week because of an agreed engagement with the amateur theater. The weekend was taken up with a trip to the summer house for my birthday.
Now having a four day weekend this week, I did some work first then got Peter over to do more. I have been preparing the inner fenders for mounting onto the body, then we tested and adjusted the fit of all other front end pieces, though not the a-panels yet.
ImageIMG_20170525_182436s by frogeye61, on Flickr
ImageIMG_20170526_165514s by frogeye61, on Flickr
ImageIMG_20170526_182258s by frogeye61, on Flickr
ImageIMG_20170526_183843s by frogeye61, on Flickr
Frogeye61
Post by Frogeye61 »
The weekend was brutal, with my tenant moving, new moving in, logistical problems, internet setup, and then a day off to see the car show in Græsted. It rained cats and dogs. I stepped in a poodle.
However I did get a chance to modify the support framing for the Mini. The doors must be tested before anything is fit permanently onto the front end.
Modified framing. The vertical post is for lifting purposes.
ImageIMG_20170605_141607s by frogeye61, on Flickr
Left door first fit.
ImageIMG_20170605_140529s by frogeye61, on Flickr
Right door first fit.
ImageIMG_20170605_152846s by frogeye61, on Flickr
ImageIMG_20170605_151204s by frogeye61, on Flickr
rich@minispares.com
Frogeye61 wrote:. It rained cats and dogs. I stepped in a poodle.
very good..........
:lol:
Frogeye61
Post by Frogeye61 »
We have now fitted new hinges to the doors and mounted them to the A panels. After a bit (lot) of fettering, the door and A panel both fit onto the A post and inner fender with reasonable gaps around the door. This includes the sill top, front door opening panel, angled side seam, front fender etc.
ImageIMG_20170607_073652s by frogeye61, on Flickr
So then after marking, we pulled off the inner fender, cleaned and sanded, readying for the spot welder (and some plug welds), also rust protection inside the bulkhead crossmember. First job is that I need to finish the "Stiffener/Box Plate 11.36.03.03", which I'm not replacing, just repairing.
ImageIMG_20170607_073622s by frogeye61, on Flickr
llmikeyj
Post by llmikeyj »
Just a thought, have you refitted your door seals when testing the door fit? Mine were fine until I put the rubbers in. Nightmare thereafter...
Mike
