Mk1 heater casing side
Posts are automatically deleted after 6 months.
Rev 1.2 (16.09.20)
Looking for a Mk1 heater casing side, the one that the hose fits onto.
Someone has cut the flange off this one ?!
360gts
Re: Mk1 heater casing side
Post by 360gts »
Hi Andrew,
I found two LH sides....there must be a couple of RH's somewhere...will have a dig around tomorrow. Yours for the postage.
Now, these may help you....but I think it is 4 inch diameter!...worth a look.https://www.ebay.co.uk/itm/256246858296 ... R7zboO_rYg
1071bob
Post by 1071bob »
I've got an old front intake which would be the right size, should be easy to weld on.
360gts
Post by 360gts »
Sorry Andrew, no luck in finding a RH side....strange that I have two LH's and no Rh's.
rpb203
Post by rpb203 »
Andrew is that panel the same on a lot of the later heater units up to the early ‘80’s?
I maybe wrong, so apologies if that’s the case.
Thanks for looking Dermott, appreciated
Bob, that’s an idea if worst comes to worst .
Gary, maybe … I have a later heater somewhere .
Toby
Post by Toby »
On early heaters that flange is part of the side of the heater hopusing itself, on the later ones it's a plastic housing which is popriveted in. The change point was somewhere in 65
olddave
Post by olddave »
Hi Andrew,
I presume you got sorted with your heater outlet.
I've just found this in my collection if you need it. Off a Mk3.
Dave
