12H733 - Vacuum Pipe with Fuel Trap
Rev 1.2 (16.09.20)
Rev 1.2 (16.09.20)
Looking for a NOS/original in good condition of the above.
I bought one from Mini Spares and the pipe between the fuel trap and carb is to short.
I saw on Bull Motif's website a photo of this item with the correct amount of pipe, sadly when it arrived it was the same as the Mini Spares one!
Any help gratefully received.
G.
G.
- mk1
Re: 12H733 - Vacuum Pipe with Fuel Trap
Minispares don't list a 12H733
Do you have a picture?
12H733 was also used on MGB, that might give you the extra length needed
My mistake I bought it from Somerford!
G.
This what I need (this is what Bullmotif show, but sell the same as the on above. G.
What engine is it for and which part is too short (which side of the bulb).
I think I have a couple used ones of 850 engines but will have to check tomorrow.
Hi again Andrew,
In the top (Somerford) photo, the shortest pipe (to the left of the fuel trap) is approx. 5 3/4 inches, it needs to be nearly double that to allow for it to be cut to size.
Any assistance gratefully received!!
I have to add that both Somerford and Bullmotif have agreed to refund me (albeit I have to pay the return postage!!).
G.
G.
Would v-good used be any use ?
It certainly would Alex?
Not planning a visit to Goodwood in the foreseeable future are you?
TIA, G.
TIA, G.
Yes, as I need to drop off Lego advent calendars to my Godsons (I think you met them very briefly).
I'll have a look through the donor engines and boxes of bits for one.
I did indeed meet your two Godsons.
I'm not sure whether they or I was the most excited as you took my windscreen and your Settrington out of the back of your van!
Any update on the vacuum pipe from yourself or Andrew?
TIA, G
TIA, G
