2 A 3709 gearbox bearing
Rev 1.2 (16.09.20)
Rev 1.2 (16.09.20)
- woodypup59
Has anyone got one of the above - in serviceable or better condition ? NOS even better.
Its the first motion shaft ball bearing for 3 sync boxes.
- Rolandino
Re: 2 A 3709 gearbox bearing
Minispares has them in stock, bit steep at £135
Guessworks also has a few
- woodypup59
I'm told that new new ones are slightly larger - so the case would need line boring - which I want to avoid.
- Rolandino
I will ring Gary at Minispares and ask him to measure one up. Will let you know tomo. R
All the n.o.s ones I have fitted are the exact size, the stock that Minispares and Guessworks have are n.o.s so you should have no issue with fitment. I have just checked a new one against a used one with the vernier - both identical.
These bearings have not been manufactured in RHP form for over 15yrs.
- Rolandino
Here goes :
OD 62.43mm
ID 25.40mm
Depth 15mm
OD 62.43mm
ID 25.40mm
Depth 15mm
I think they are imperial size bearings
- Rolandino
Use a calculator, or better still measure your bearing in metric!
