Looking for a thrust washer 0.117 to 0.118 for a Cooper S, before I spend £28 on a new one.
Cheers Jim
Primary Gear Thrust Washer
Rev 1.2 (16.09.20)
Rev 1.2 (16.09.20)
Re: Primary Gear Thrust Washer
I’m sure I could help - I’m away until Friday but will look then if no one else comes forward
High Graeme, have you had a chance to look for a thrust washer ?
Cheers Jim
Cheers Jim
Oops, sorry I forgot.
Is it a large or small bore one you’re after? Are the primary gear bushes the same internal diameter or is the front one larger for the stepped crank?
Hi Graeme, yes large bore with stepped crank.
