Wanted central Cover for Steering Wheel
Rev 1.2 (16.09.20)
Polarsilver
Post by Polarsilver »
Wanted 1x Central Cover for this Wheel .. the Boomerang Cover ( shown) that i thought was correct WRONG.. so long shot can the Forum supply this "Steering Wheel with its Central Cover " this wanted central Cover is located with 6 x square Tangs & two Screws... approx length of this Cover is 121/8 inch long
I cannot see any Part Number on this Steering Wheel ..Maybe is not Mini ?.. but it fits MK3 Colum .
'S'-type
Re: Wanted central Cover for Steering Wheel
Post by 'S'-type »
Polarsilver wrote: Sun Jan 22, 2023 5:58 pm Steering Wheel without pad.JPG Wanted 1x Central Cover for this Wheel .. the Boomerang Cover ( shown) that i thought was correct WRONG.. so long shot can the Forum supply this "Steering Wheel with its Central Cover " this wanted central Cover is located with 6 x square Tangs & two Screws... approx length of this Cover is 121/8 inch long
It looks like you've got a very late wheel (1982 /3). Part No. Nam4943. But the cover is the first iteration of the boomerang cover used from 1977-1980. Part No. Fam4646.
The late wheel cover has a wider profile and I believe is held in place with four clips. As opposed to the earlier two. ( Different clips in each case). It also has an indent for a stick-on oblong badge and an indented perimeter moulding. Part No. Fam9672.
There were three different arrangements for the boomerang wheel.
1977-80 Wheel Part No. 21A2581 Cover Fam4646
Narrow cover no badge.
1980-82 Wheel Part No.21A2581 Cover Fam9621
Narrow cover with oblong indent for badge.
1982> Wheel Nam4943 Cover Fam9672. Wider crossbar and cover with badge.
So it depends what year you have. I don't know when the change points were in 1980 and 1982.
I've got the complete early version here for £40.
pdb
Post by pdb »
I have this Austin steering wheel fitted to an ADO16 column. Let me know if you are interested in the complete wheel or the cover.
'S'-type
Post by 'S'-type »
This is what the late version looks like.
What year is the pick up Norman
That cover is correct for a 1980 pick up .. it’s what my very original one owner pick up had.
'S'-type
Post by 'S'-type »
Mine is the same as Andrew's.
PM sent.
