I am looking for a maniflow manifold for my set of HS6 carbs. Should have 35mm diameter on the inlet port to match the head.
I am also interested in a set of HS4 carbs with manifold (alao 35mm…).
Carbs are for a rally cooper s engine.
Thank you and kind regards
Thomas
Twin HS6 steel manifold or twin HS4 set
Rev 1.2 (16.09.20)
Rev 1.2 (16.09.20)
- Lenhamracer
Re: Twin HS6 steel manifold or twin HS4 set
Years ago I ordered a Maniflow steel intake for a set of HS4s. I carefully cleaned it up with porting rolls and had it ceramic coated and placed it on the self. When I decided it was time to use it I realized it's a HS6 intake. While I have HS6 carbs my current big project will run a 48 IDA system. Shipping and customs across the pond has been a deal killer for several items I have offered. It is truly a nice pc. Calver picked it out from a big batch. Steve (CTR)
- Lenhamracer
That sounds very good. It might be possible to send it to a friend near London and she could bring it over when she comes to cologne. Or would you post to Germany?
Can you send a picture and a price?
Is it the 35mm type?
Thank you very much
Thomas
Thank you very much
Thomas
- Lenhamracer
Sorry - I just noticed that you are in the states. That would really be too costly...
All the best
Thomas
All the best
Thomas
That's what I said about getting parts over. Just a quick check with stick ruler 35/36mm. It is beautiful. I have offered to provide parts no charge and shipping and customs killed the deal. Sorry Steve (CTR)
