Steering Wheel Boss
Rev 1.2 (16.09.20)
Spitz
Steering Wheel Boss
Post by Spitz »
Looking for a boss
for this wheel.
Pref with a Morris horn push
Re: Steering Wheel Boss
Well finding an original LL Monte boss is like a needle in a haystack. You have two options, buying a replica from Nippycars or use a Astrali 1A boss. The Astrali boss mk1 will do the job nicely but the six holes are not 100% in line.
If you adjust the holes in the boss slightly you will have a perfect setup.
Very nice steeringwheel by the way.
Kees.
Fanfaniracing
Post by Fanfaniracing »
I have this Astrali Boss for Sale...
Spitz
Post by Spitz »
Would this fit my wheel? What is the measurement between holes.
edit: Astrali....so the same as the pictured one above......holes are slightly off
Yes it will fit your steering wheel, on my pictures you see how the holes are on an 1A Astrali boss.
If you adjust the holes of the boss a bit you have a perfect fit, you don't need the ring.
Don't adjust the holes on your steering wheel please :roll:
Kees.
