gear box parts for 1800 gear box
Rev 1.2 (16.09.20)
roger mcnab
Post by roger mcnab »
hi i am having some difficulty in finding a collar part no 22h767 also slip joint boots 2 off part no 18g9029 mini ones are to small
cheers roger mcnab
Re: gear box parts for 1800 gear box
Roger, I’ll ask Dad as he has some Landcrab parts.
An Autojumbler friend had some a while back, I’ll ask him as well for the shaft gaiter.
So you have a photo of the collar ?
Hi Roger,
Found this NOS gaiter ... will ask my autojumble friend if he still has his.
Will also look up that collar and see if we can help.
No luck with that collar I’m afraid.
Might be worth talking to Tony Wood, the parts contact for the Landcrab club .
roger mcnab
hi well that boot looks great as i am in australia how do we go from here i use paypal
postage is not that expensive i will wait to here from you cheers roger :D
Hi Roger,
Paypal is fine.
Would a good used original be of interest ? If it is, I'll have a look in the shed at Dads Landcrab used spares.
Regards
Andrew
roger mcnab
hi andrew
any parts will be fine i have a pair of old ones and i mean old newer ones would be better but what ever i can get is fine
i have a collar c
located and also have a new one lurking in the shed also think one came with the spare box i bought also got one with one end shorter which will worh as the gear slides over it holding it in position but i like things to be good and with the v8 going through the box will be interesting
cheers roger
I'll have a look at the weekend and let you know if I find anything.
Jason
Post by Jason »
Little bit away from the original subject, but is this Churchill socket for the hub balljoints of interest?
roger mcnab
hi jason
well the project is installing a rover v8 engine and 1800 gearbox into a mini clubman with cut and welded drive shafts with the 1800 auto inner hardy spicer steel joints with mini outer shaft end and mini outer cv joints and hubs
but thank you for the kind offer but i have enough tools to nearly build a bridge :lol:
cheers roger
