Cooper S servo
Rev 1.2 (16.09.20)
ntonio
Cooper S servo
Post by ntonio »
Hi!
Does anybody know where to find a MK1 Cooper servo or a website where buy a reliable repro one at good price?
Regards
Antonio
iain1967s
Re: Cooper S servo
Post by iain1967s »
https://www.alfaholics.com/parts/105-se ... rake-servo
That’s the nearest repro I’ve seen.
Re: Cooper S servo
Did I hear that the overhaul kits are interchangeable too?
Re: Cooper S servo
Not sure of the difference to braking effect in practice but remember that not all Type 5 1/2’s are equal ….
Different bore sizes are indicated by machined grooves on nose of body. S servos have no groove.
What bore size are the repro ones ?
iain1967s
Re: Cooper S servo
Post by iain1967s »
I have one on order, so I’ll report back when I fit it in Spring.
LuisM
Re: Cooper S servo
Post by LuisM »
Hello Antonio ,
I have a genuine mk1 servo for sale , needs a full rebuild though.
Please PM me if you have any interest .
Luís
TECH396
Re: Cooper S servo
Post by TECH396 »
I looked into those Alfa ones some time ago.
I was informed that the Pressure Ratio was higher on the Alfa one, due to the larger Diaphragm size.
The bore size was 5/8". Here's the reply I got from them.
[quote....The Bendix servos are similar to Mini ones but the pressure ratio is higher on the Alfa one.
BR006 diaphragm for the BR100 servo is 6.85” o/d. the seal that goes against the piston is 5/8”....quote]
Paul H.
Nick W
Re: Cooper S servo
Post by Nick W »
I used to use the alfa one one my old green S, it worked perfectly fine.
The mini spares one, is a more accurate looking one, but don't think they make it any more due to some having issues. Although the 2 that I fitted worked fine.
Up North in Sheffield
spoon.450
Re: Cooper S servo
Post by spoon.450 »
I once had an Alfa servo but was put off slightly as it had metric ( M10 x 1 ) threads for the brake pipe fittings, rather than the 3/8 UNF as Mini.
jaknight
Re: Cooper S servo
Post by jaknight »
Nick W
I purchased a Mini Spares reproduction brake servo a few months back but not installed.
Do you know what issues those servos may have ?? That concerns me as to the safety depending upon issues.
Jim K
