Original AUD146R tag wanted - swap for AUD146L - Also airbox screw
Rev 1.2 (16.09.20)
I need an AUD146R float chamber tag please :)
Will swap for this AUD146L tag. ;)
Thanks in advance
Re: Original AUD146R tag wanted - swap for AUD146L - Also airbox screw
Also need one air box retaining screw .. like this one ..
timmy201
Post by timmy201 »
Nick Rodgers had the wingnuts
Thanks Tim,
I'll message Nick :)
nick rogers
Post by nick rogers »
Here it is, Andrew.
Excellent … I’ll message you :D
Hipwell
Post by Hipwell »
Not sure if you found some original tags...
But I can make some up pretty close if your struggling.
Hi Matt,
I think I am sorted now but will let you know if I need one - looks very good :)
Regards
Andrew
winabbey
Post by winabbey »
Hipwell wrote: Thu Aug 19, 2021 10:14 pm Not sure if you found some original tags...
Would love some background to your tags.
Did you buy the tags themselves from SU or make them yourself? What size font is the stamp set you used?
I'm not wanting to compete with you, just needing some unique specification tags for my own application.
Do you produce stamped tags as a service? If so, what do you charge? I'm in Australia.
moita
Post by moita »
Very nice replica Tags. I guess you are able to Do you do for other numbers, too?
