Boot latch and ignition switch dated 08 64
Rev 1.2 (16.09.20)
mark h
Post by mark h »
As per the title I am after a boot latch and ignition switch dated around aug 64 or as close a possible. Thanks
Terrapin-52
Re: Boot latch and ignition switch dated 08 64
Post by Terrapin-52 »
HI Mark
I have a boot latch that go's in the boot lid for the handle, how do you know the year on it?
it has (after cleaning) 3'9817 stamped on it along with WB below (makes stamp?) and Pat Pend
regards mike
1982 mini City
Terrapin chassis No'52, with A series engine/box
mark h
Post by mark h »
Mike,
The photo shows the latch I need , the date is stamped on the face or on the top lip.
Mark
Terrapin-52
HI Mark
found it on the top face/lip, it is 11/63, not quite 64, I have the boot handle and the drivers door handle (no key's) if any good?
I need to clean out the shed and there may be something down there, will have a look at the W/E as to what is there
regards mike
1982 mini City
mark h
Post by mark h »
Mike, thanks for checking , sadly not close enough. Thanks Mark
Toby
Post by Toby »
I have a latch dated 12 64 if that's any good
