Hardy Spicer diff ouput shaft
Rev 1.2 (16.09.20)
MrNoo
Post by MrNoo »
Hi, I am after one or two (ideally a pair) of diff output shafts for use with the Hardy spicer UJ. It is 23 spline and used on Cooper S and automatics. I'm afraid I dont have a part No but picture below. Many thanks.
65MK1S
Re: Hardy Spicer diff ouput shaft
Post by 65MK1S »
I think the part number is 22A1151
hanlminiman
Post by hanlminiman »
It would be helpful if "wanted" posts identified approximate location of member, UK (county) or other (country). Just a suggestion.
MrNoo
Post by MrNoo »
hanlminiman wrote: Sat May 01, 2021 7:22 pm It would be helpful if "wanted" posts identified approximate location of member, UK (county) or other (country). Just a suggestion.
Have changed my settings. I have now located a pair, many thanks.
MrNoo
Post by MrNoo »
Been let down, so after one still to make up a pair if anyone has one kicking around. Happy to take a complete diff if it helps.
Craig
Post by Craig »
If you have no luck in the UK , I have some .
I'm located in western Canada though ...
Craig
MrNoo
Post by MrNoo »
Craig wrote: Fri May 07, 2021 7:00 pm If you have no luck in the UK , I have some .
Craig
Hi Craig, many thanks. We are going to try and straighten it, the engineering bods reckon they can, so we've nothing to loose as it's scrap currently!
BRI MK1
Post by BRI MK1 »
i have a pair
MrNoo
Post by MrNoo »
BRI MK1 wrote: Tue May 11, 2021 7:32 pm i have a pair
Have PM'd you!!
