Wanted - 1x Mark 1 Cosmic rim - total width 140mm
Rev 1.2 (16.09.20)
snoopy64
Re: Wanted - 1x Mark 1 Cosmic rim - total width 140mm
Post by snoopy64 »
If you get one more member you can buy a set!
Kevin
MiNiKiN
Post by MiNiKiN »
mk1 wrote: Thu May 06, 2021 2:38 pm I am sending a couple of Cosmic RW10S's for him to sort very soon & have used him before.
Have you finally found a set?
I managed to find two more, so I have now 5 after a years search. One is a bit different where the hub caps sit and has no "Cosmic patented writing" on the inside and the other has been welded at the rim bead and needs more welding on the inside where the brake disc has chaffed quite a bit from the rim well off. Suppose the rim once came loose .....
Luckily they were inexpensive (at least this is what I am telling myself :roll: ).
If only I knew the power of the Dark Side...I wouldn't have made contact with an Innocenti :mrgreen:
Yes, I have finally managed to get a (nearly) set. But as with all things that I touch. I have now changed my mind & am probably not going to use them. Still getting them restored though.
General dogsbody.
MiNiKiN
Post by MiNiKiN »
mk1 wrote: Thu May 06, 2021 3:51 pm Yes, I have finally managed to get a (nearly) set. But as with all things that I touch. I have now changed my mind & am probably not going to use them. Still getting them restored though.
Though not fitting you probably keep them, don't you?
Yes, for the moment. . .
Need to get them sorted first.
General dogsbody.
