Sell Multlple Parts
Want to sell something? Here's the place to list it for free! (DIRECT SALES / SWAPS) No ebay links please.
Posts are automatically deleted after 3 months.
For Sale Section Rules
1) This section is for advertising items that you have for sale. Not for the discussion of listed items. If you wish to debate the pro's & Con's of any item listed, please start a new topic in the appropriate section.
2) Please DO NOT post links to your ebay auctions. This section is NOT for the advertisement of your ebay auctions.
5) Items listed for sale should WHEREVER POSSIBLE* be offered with a purchase price, not asking for bids from members. If you wish to auction your item to the highest bidder I would suggest you use ebay & pay the associated fees.
6) This section is offered as a free service to enthusiasts. Any deals made are between the buyer & seller only. The MK1 forum takes no part in any transaction & the appearance of any item in this section is not a recommendation. I strongly suggest that both buyers & sellers are happy to proceed with a deal before any money or goods change hands.
7) It expected that people posting items for sale are "Active Members of this community". Any Adverts placed by members with a post count lower than 5 will be deleted.
8) The advertising of or soliciting for VIN tags, log books or any other vehicle identification documentation without it's associated vehicle is expressly forbidden. Any member breaking this rule will have his membership terminated with immediate effect.
9) If a moderator considers any postings in this section to violate either the spirit or word of these simple requests the MK1 Forum reserves the right to delete any posts without prior warning or explanation.
10) The posting of items for sale on the MK1 forum constitutes explicit acceptance of these simple rules.
11) Members posting items for sale MUST include a rough location in their profile.
It would be much appreciated if sellers could leave the sale price on adverts after the item has been sold. This acts as a good measure of current value for other sellers.
* In some cases it may not be possible for the seller to list items with a sale price. In this case, listings will be reviewed on a case by case basis by a moderator. The moderators decision will be final.
Rev 2.10 (06.10.20)
Polarsilver
Sell Multlple Parts
Post by Polarsilver »
Listing Multiple Parts that i can "deliver" to Gaydon Mini days or MCR Mini Day .. or can Post any item at buyers cost.
5. Morris Mini Minor "Drivers Handbook AKD1174B" not perfect .. what do you expect for £10 .
6. Speedo End casing fit gearbox 22A110 @ £10
7. Red T Handle Bowden Cable outside fit for Battery or Fire system . nos @ £10
8, Pair Clubman Interior Ball Vents used @ £10 ( not chrome)
9. Lucas Starter Motor C40 lo12v 25098 0-61 Made in England 9 tooth shaft is early type with the split pin through the end nut not tested @ £40.
10. Leyland Mini Handbook 850/1000 used @ £10.
12.Pair mk1 Overriders good chrome not drilled @ £10.
13 Rod Change Gearbox .DAM3220 A/BZ3 std ratio with helical 31 teeth Drop Gear . 17 t Pinion / 64T Crownwheel . good sump plug threads.
Light fin damage underside .. gearbox drove well with no issues Used item at £100
14. Moke Mud Flaps used fronts pair @ £20
15. Brake Pressure Valve 4 port bulkhead mounted for later split brake systems used @ £20
17. Mono aftermarket chrome Gear Knob slight lower damage used @ £10
18.Fiamm Twin Air Horns. alloy Horns + Harry Moss Compressor. red tube mounting bracket etc Tested & Good Sound used @ £125
19 Fiamm Twin Air Horns .alloy Horns + Harry Moss Compressor. red tube + mounting bracket etc .Tested & Good Sound used @ £100
20 Fiamm Twin Air Horns alloy chrome Trumpets . Harry Moss Compressor, red tube + mounting Bracket etc these are NOS tested @ £225
21.Round Steel Mesh Air Filters pair for HS2 aftermarket type used @ £10.
22. mk1 Dipstick.. type with flatwasher contact to the surface onto Engine block Used @ £15.
24 Clutch Cover ( Woks) ask for the type needed used @ £15 each
26. Lucas Distributor 45D$ 41449-50-77 with Vac Used no body damage used @ £20.
27.Pair mk3 Rear Side Windows with Frames. Indestructo Glass. normal light rust to spring hinges etc will re-live .. odd is outer frame on one is two section the other window the outer frame is in one section used @ £35 the pair.
28
29. Chrome Rocker Cover no breather outlet . chrome is fair condition used @ £10
30.3off Door Handle with Locks type for wind window cars excellent chrome possible nos with key numbers FS925 + FS918 the lot at £35
31 Sold
32 Alloy Checker Kick Strips for mk1 door threshold used x 3off the lot used @ £15
33. 2off Purolator Oil Filter Heads & Canisters units . one has a steel filter canister the other with an alloy canister . both come with the Filter head & the through bolt with the inside bits these units need a good clean but are not dripping oil at £40 the used pair
36.Roll Over Jig for Bodyshell has be used on mk1 + mk3 +pick up & clubman @ £100 works a treat.
37. Front Body Panel of mk2 type for rubber mount subframe this is ex Leyland NOS @ £90
38. mk3 Steering Colum with ign switch & steering lock ..sorry no ign key @ £10
39. mk1 Fuel Tank "Securing STRAP "two section used @ £15.
40."Fork End Selector Shaft" that fits inside the gear shift Remote tunnel NOS item at £20
41.
42. H4 Twin Carbs Complete with inlet manifold all set up with linkages+ choke bridge + spring anchor brackets etc.. have been restored & just need the relevant to the car Needles (needles not supplied) this is a complete H4 twin carb package ready to fit @ £1,400.
43. Mk1 Steering Wheel in good condition @ £120
44. Sold
45. Sold
47. 12A145 Cylinder Head with valves & springs @ £25.
48. Sold
49. Rear Grey Black Deckchair two part seat for 1275GT @ £100
50. 4x Spax Sock Absorbers in yellow marked crypton front & rear little use ..i have no idea if the are standard length or short @ £60.
51. mk1 Reclining Seat in Green probably ex Elf / Hornet good green covers but needs tidy up underside @ £50.
52, Drive Shaft to distributor .. good @ £20
53. Timing Cover type with Breather Cannister @ £20
54. 16 Teeth Pinion Gear nos in Leyland box @ £20
BMC B Series Cylinder Head complete used (maybe ex MGB ) me no expert.. heavy item so can take to Gaydon @ £20
Moulton Standard Bike 4 speed . My Family owned from new 1965 year good clean and tidy bike.. they are Cool @ Blyton this year 8-) .. £ 250 ono or the Moulton is FOC if you buy the Moke ;)
send pm & ask if you need items photo ..me still finding stuff so more to follow.
Toby
Re: Sell Multlple Parts
Post by Toby »
PM sent
Smithmaps
Post by Smithmaps »
I'll take 16. the fly off handbrake please.
I will PM
tjw89
Post by tjw89 »
Pm sent
Mrgoose
Post by Mrgoose »
PM Sent about 35 & 39
Nick W
Post by Nick W »
Could I take number 23 please.
Nick
Up North in Sheffield
steve1071
Post by steve1071 »
Can I have no. 2 please?
Polarsilver
sent you all a response pm. thanks N
Item 25, SU bits please Norman. PM sent too
Polarsilver
Having grief with my internet or whatever stopping me sending emails or even normal entry to the forum .so just a note to say anything purchased has been sent out .. anything we agreed I will take to Bingley car park and will message you when on site. Thanks to all the interest I will reappear asap once I can get internet or probably my hard wear issues sorted out cheers N
