Jack Knight gearbox assembled and tolerances checked by Dan Howell Classics.
Gearbox has only done one track day.
22G1128 Gearbox casing with ADO16 diff housing and remote, solid mounting.
Remove pre-pump filter adapters machined and fitted to the front the front of the gearbox case along with modified oil pick up.
Straight cut Jack Knight Development's dog gear set.
Ratios
1st 2.16 2nd 1.46 3rd 1.18 4th 1. Reverse gear 18/17 tooth.
Straight cut MED crown wheel and pinion set on Tranex style plate LSD.
Differential 3.75:1 F/D ratio.
Straight cut drop gear set : ratio 24/30/24-1:1.
Hardy Spicer Outputs
£3150
Jack Knight Gearbox
For Sale Section Rules
1) This section is for advertising items that you have for sale. Not for the discussion of listed items. If you wish to debate the pro's & Con's of any item listed, please start a new topic in the appropriate section.
2) Please DO NOT post links to your ebay auctions. This section is NOT for the advertisement of your ebay auctions.
5) Items listed for sale should WHEREVER POSSIBLE* be offered with a purchase price, not asking for bids from members. If you wish to auction your item to the highest bidder I would suggest you use ebay & pay the associated fees.
6) This section is offered as a free service to enthusiasts. Any deals made are between the buyer & seller only. The MK1 forum takes no part in any transaction & the appearance of any item in this section is not a recommendation. I strongly suggest that both buyers & sellers are happy to proceed with a deal before any money or goods change hands.
7) It expected that people posting items for sale are "Active Members of this community". Any Adverts placed by members with a post count lower than 5 will be deleted.
8) The advertising of or soliciting for VIN tags, log books or any other vehicle identification documentation without it's associated vehicle is expressly forbidden. Any member breaking this rule will have his membership terminated with immediate effect.
9) If a moderator considers any postings in this section to violate either the spirit or word of these simple requests the MK1 Forum reserves the right to delete any posts without prior warning or explanation.
10) The posting of items for sale on the MK1 forum constitutes explicit acceptance of these simple rules.
11) Members posting items for sale MUST include a rough location in their profile.
It would be much appreciated if sellers could leave the sale price on adverts after the item has been sold. This acts as a good measure of current value for other sellers.
* In some cases it may not be possible for the seller to list items with a sale price. In this case, listings will be reviewed on a case by case basis by a moderator. The moderators decision will be final.
Rev 2.10 (06.10.20)
Rev 2.10 (06.10.20)
Jack Knight Gearbox
Last edited by Reborn Cooper S Man on Mon Dec 04, 2023 11:27 pm, edited 4 times in total.
Re: Jack Knight Gearbox
Hi,
Is the ADO 16 sandwich plate welded to make it solid, or an aftermarket part?
Ray.
Ray.
Hi Ray
The rubber has been removed from the plate then welded to make it a solid mount.
Hope that helps.
Ian.
Hope that helps.
Ian.
Hi Ian,
That is what I have done to all of mine, although I think I have seen a solid aftermarket one somewhere.
Hope it gets sold, looks a great bit of kit
Ray
Ray
Thanks Ray
