This is a South African Clubman 1275E that is fully rebuilt with the following items.
60 thou oversize AE/Nural pistons and rings thus 1330cc now
Mains bearings 20 thou, big-end bearings 20 thou, thrust washers STD and AP oil pump.
Cam bushes replaced and cam followers, single row timing chain.
Standard 1275E camshaft
Cylinder head serviced with new valve guides and stem seals, 33mm inlet valves, 29mm exhaust valves
DAM4818 Gearbox rebuilt with new 3 step layshaft, layshaft bearings and baulk rings. Fitted with DAM3168 gearset and 3.44 diff.
High flow Water pump, bypass hose, thermostat and thermostat housing and studs and welsch plugs all round.
Flywheel and backplate machined.
Engine was run on test stand and had great oil pressure.
Price R28 000 or GBP1200
Shipping for the buyer's cost.
Item is based in Pretoria, Gauteng Province, South Africa.
sales@classicminishop.co.za or (0)+27 72 758 7740
1275E Clubman Engine for sale
For Sale Section Rules
1) This section is for advertising items that you have for sale. Not for the discussion of listed items. If you wish to debate the pro's & Con's of any item listed, please start a new topic in the appropriate section.
2) Please DO NOT post links to your ebay auctions. This section is NOT for the advertisement of your ebay auctions.
5) Items listed for sale should WHEREVER POSSIBLE* be offered with a purchase price, not asking for bids from members. If you wish to auction your item to the highest bidder I would suggest you use ebay & pay the associated fees.
6) This section is offered as a free service to enthusiasts. Any deals made are between the buyer & seller only. The MK1 forum takes no part in any transaction & the appearance of any item in this section is not a recommendation. I strongly suggest that both buyers & sellers are happy to proceed with a deal before any money or goods change hands.
7) It expected that people posting items for sale are "Active Members of this community". Any Adverts placed by members with a post count lower than 5 will be deleted.
8) The advertising of or soliciting for VIN tags, log books or any other vehicle identification documentation without it's associated vehicle is expressly forbidden. Any member breaking this rule will have his membership terminated with immediate effect.
9) If a moderator considers any postings in this section to violate either the spirit or word of these simple requests the MK1 Forum reserves the right to delete any posts without prior warning or explanation.
10) The posting of items for sale on the MK1 forum constitutes explicit acceptance of these simple rules.
11) Members posting items for sale MUST include a rough location in their profile.
It would be much appreciated if sellers could leave the sale price on adverts after the item has been sold. This acts as a good measure of current value for other sellers.
* In some cases it may not be possible for the seller to list items with a sale price. In this case, listings will be reviewed on a case by case basis by a moderator. The moderators decision will be final.
Rev 2.10 (06.10.20)
Rev 2.10 (06.10.20)
