Pre-spring clearout
Posted: Tue Jan 24, 2023 8:21 pm
Having a pre spring clear out of the garage as I’m running out of space, so.....
Britax Autolock seat belts, will require restoring and re-webbing – looking to sell as a job lot (I think there are 4no. units in total) - SOLD
Early (pre65) crackle sunvisors – good condition - SOLD
Original Stadium rear view mirror - SOLD
3 Synchro Cooper gear box – 22G68, incl Diff. The box has the original laygear and gears with all new bearings, layshaft, synchro rings spring balls etc… except for the 1st motion bearing which is fine and serviceable. The diff has new bearings, output bushes, planetary gear bushes, seals etc… Requires a check over but pretty much ready to bolt on (even painted green) - £600.00
Complete remote, will require a clean down, re-grease and the gear shift will require re-chroming - £225.00
Complete 998 engine (12A1456 head) (engine no. 99H-141-H++++) with a 22A1288 gearbox (remote type) – gearbox is complete but will require cleaning down and servicing. The small engine has been stripped and all parts incl (no carbs) - £300.00
A set of 5no. 4.5x10” Avon Safety Wheels, incl chrome centre caps, these have been refurbished and are ready to bolt on - PROV SOLD
Hopefully I can get in the garage tomorrow and upload some photographs, I’m also heading to the mini show in Stafford on Sunday if that helps?
Thanks.
Thanks.
