Garage Clearance, Various Parts For Sale
Want to sell something? Here's the place to list it for free! (DIRECT SALES / SWAPS) No ebay links please.
For Sale Section Rules
1) This section is for advertising items that you have for sale. Not for the discussion of listed items. If you wish to debate the pro's & Con's of any item listed, please start a new topic in the appropriate section.
2) Please DO NOT post links to your ebay auctions. This section is NOT for the advertisement of your ebay auctions.
5) Items listed for sale should WHEREVER POSSIBLE* be offered with a purchase price, not asking for bids from members. If you wish to auction your item to the highest bidder I would suggest you use ebay & pay the associated fees.
6) This section is offered as a free service to enthusiasts. Any deals made are between the buyer & seller only. The MK1 forum takes no part in any transaction & the appearance of any item in this section is not a recommendation. I strongly suggest that both buyers & sellers are happy to proceed with a deal before any money or goods change hands.
7) It expected that people posting items for sale are "Active Members of this community". Any Adverts placed by members with a post count lower than 5 will be deleted.
8) The advertising of or soliciting for VIN tags, log books or any other vehicle identification documentation without it's associated vehicle is expressly forbidden. Any member breaking this rule will have his membership terminated with immediate effect.
9) If a moderator considers any postings in this section to violate either the spirit or word of these simple requests the MK1 Forum reserves the right to delete any posts without prior warning or explanation.
10) The posting of items for sale on the MK1 forum constitutes explicit acceptance of these simple rules.
11) Members posting items for sale MUST include a rough location in their profile.
It would be much appreciated if sellers could leave the sale price on adverts after the item has been sold. This acts as a good measure of current value for other sellers.
* In some cases it may not be possible for the seller to list items with a sale price. In this case, listings will be reviewed on a case by case basis by a moderator. The moderators decision will be final.
Rev 2.10 (06.10.20)
Having a bit of a clear out of my lock ups. All prices include signed for postage to the UK. I will discount the prices if you buy more than one item. Overseas buyer please ask for quote as the cost depends on the item and destination, thanks. (Pictures for each item can be found on the Page indicated)
Pair of Late Mk1/Mk2 Door Handles £25
Accessory Switch and Warning Lamp on Crackle Finish Bracket £25
Klark Gear Lever Extension £10
Recirculatory Smiths Heater Unit £90
Black single gauge 850 Saloon/Van/Pick-up Speedo Pod. £30
HS4 SU Carb Spacer £10
GDS 102 Ignition Shield £20
NOS Lucas LHT 3 Ignition Lead Set £30
Slip-On Fit Mk3 Washer Bottle £15
Non-Vented Stainless Steel Petrol Cap £25
Original Austin/Morris 1800S Badge £10
British Leyland A-Panel Badge £15
Original 1967 Onwards AA badge £25
1963 AA Badge £20
Mk2 Mini Bonnet Badge Surround £20
Mini Mk2 Handbook, Late 1968 £15
British Leyland Wade Ashtray £35
Les Leston Steering Wheel Ashtray by Beswick £50
All sensible offers considered
Re: Garage Clearance, Various Parts For Sale
Pair of late Mk1/Mk2 door handles. There’s a bit of pitting and scratching to the chrome. There is no key for the lock. What you see is what you get. £25
Accessory Switch and Warning Lamp on crackle finish bracket. If your Mk2/Mk3/Clubman/GT had a heated rear window, this is the style of switch and lamp that was fitted. Switch has a nice solid click action, the warning lamp has some slight chipping to lens. Not tested £25
Klark Gear Lever Extension. Used condition and looks like someone's had a go at it with pair of pliers as there are some tool marks on the flats £10
Smiths FHR2315/04 Recirculatory Heater Unit. Complete with matrix. Motor and matrix not tested £90
Black single gauge 850 Saloon/Van/Pick-up Speedo Pod. This is in good condition with no cracks at the mounting points. Could do with a bit of a polish £30
½” thick alloy carb spacer for 1 ½” HS4 Carb. £10
GDS 102 Ignition Shield. The original type ignition shield that is fitted to the rear of the front panel. Unfortunately there is a crack in it, however this would not be visible once fitted. £20
Lucas LHT 3 Ignition Lead Set. Unused copper suppression Lucas lead set with Champion caps, the coil lead has a screw fitment for acorn style coils. 2x 10.5" plug leads, 2x 12.5" plug leads, coil lead is 10" £30
Slip-On Fit Washer Bottle as used on early Mk3/Clubman and GT cars. Used yellowed condition complete with cap. Great for the original look and better than the bleached white ones you can buy new £15
Used Non-Vented Stainless Steel Petrol Cap. There are some small dents in the cap as seen in the reflections, also a bit of surface rust on the inside £25
Original S badge. These were originally fitted to the Austin/Morris 1800S, but they were also supplied as part of the 1275GT S pack for attaching to the boot. Slight pitting to chrome and the red could do with a touch-up £10
British Leyland A-Panel Badge, in good condition £15
Original AA badge. Never fitted in as new condition. This type of badge was first introduced and given to members from 1967. Ideal for MK2 onwards Minis for that correct period look. Come complete with all mounting hardware. £25
1963 AA badge in original condition complete with hardware for grille fitting. It still has the rings holding that hold the two parts together, but they are loose. £20
Mk2 Mini Bonnet Badge Surround as fitted to all 850 and 1000 saloons, Countryman/Traveller and Mk2 era Vans and Pick-ups. Has some pitting in the chrome but all three mounting pins are intact. £20
Mini Mk2 Handbook, Late 1968, publication number AKD 4992A. It very good condition with wear and marks to cover. There is an addendum for the soft type heater and choke cables, so it is for later Mk2 models. It has some hand written notes and someone has kept a service log. £15
British Leyland Wade Ashtray. Finished in bright blue with a printed BL roundel in the middle. It is in excellent condition with no chips, cracks or crazing to the glaze. As nobody smokes anymore this can be used as a key storage unit or a desk tidy for all those paper clips and drawing pins. £35.
Les Leston Steering Wheel Ashtray produced by Beswick. It is in good to excellent condition with no chips or cracks, but does have some slight wear to the chrome on the wheel spokes. £50
