Straight cut gears
BLACKJACKф
Straight cut gears
Post by BLACKJACKф »
I'm considering switching to straight cut gear box and drop gears I heard it's quite loud. But what is loud mean? So my silly question I guess is which is going to make the louder sound just changing the gearbox only or just changing the drop gears only.? Obviously doing both together would be the loudest.
timmy201
Re: Straight cut gears
Post by timmy201 »
Here's an idea of the noise for you:
https://youtu.be/gW3W0LMdU_Y?si=Vl2mXgsrw9V_O8ky
On all gearbox gearsets first gear is straight cut
On a straight cut gearset the noise will be similar to standard in first gear, then 2 & 3 will be much louder. 4th gear shouldn't be as bad as 2/3, as the power isn't passing through the straight cut gears
The straight cut drop gears are noisier, and are loud in every gear
CooperTune
Post by CooperTune »
I have had good experiences with REM treatment of all gears. I think Swiftune offers gear sets called super finished? I have read it reduces drag 2 HP per 50 HP produced. I have CWP, drops and all gears REM and cryogenic treated. It works. Steve (CTR)
Pete
Post by Pete »
Some straight cut gear sets are barely any louder than standard, depending on if your car has any soundproofing, trim etc but most straight cut drops are significantly louder. Some might say they’re a bit of an unnecessary expense on road car but I actually quite enjoy the sound of mine (both) albeit it’s no motorway car!
Exminiman
Post by Exminiman »
Years ago Vizard did an article in CCC about straight cut gears, I am sure he talked about topping the gears to make them quieter ……might be worth looking up...but it’s quite possible I could be imagining it 😀
EMOKID
Post by EMOKID »
If you want the noise without the full expense then sc drop gears are the way to go. A+ series are quieter then the original A series.
and.rs1800
Post by and.rs1800 »
On the cars I’ve had with straight cut drops and gearbox the noise didn’t bother me at all,the induction roar from twin SU’s was louder
MrNoo
Post by MrNoo »
Drops and gears are not at all bad, certainly to my ears, it's when you have a SC final drive that makes a fair bit of noise.
Following this with interest as I'm thinking of doing something similar with 9748KO .. to get the desire for the the sound out of my system :o :lol:
kit of bits
Post by kit of bits »
I just love that noise..
I’m about to fit a sc box to the S I can always change it back if/when it drives me mad..
