Lucas 608 Mounting Bracket
Polarsilver
Re: Lucas 608 Mounting Bracket
Post by Polarsilver »
Photo of this method to adapt the Lucas Mirror & now looking at this photo realise that i need to change the screws into the cant rail :oops:
probably did not have correct countersunk screw at the time & now cannot remember the thread size :roll: Q what is the thread size into cant rail ?
3/16 UNF or 2BA fits too.
Tupers
Post by Tupers »
I believe this one has the original Mini style bracket. http://mk1-forum.net/viewtopic.php?f=5& ... =Lucas+608
The one above does. This is a 2 hole pressed steel bracket that fits straight over 2 of the 3 normal mounting holes.
111Robin
Post by 111Robin »
Not exactly up to the standard of Dr.Mabo but should be ok. The stem is brass so I couldn't weld it to my home made bracket, resorted to JB Weld. Not ideal but worth a try (still to be painted)
111Robin
Post by 111Robin »
Tupers wrote: Thu Jan 11, 2024 3:18 pm I believe this one has the original Mini style bracket. http://mk1-forum.net/viewtopic.php?f=5& ... =Lucas+608
Any idea where these can be obtained from ?.
Would that sort of bracket and fitting pass any sort of current safety criteria? I'm not one of the 'elf 'n safety inn'it' gang, but dear o' deary me, that's a recipe for shredding a forehead and eye socket in an accident
111Robin
Post by 111Robin »
Peter Laidler wrote: Thu Jan 11, 2024 6:55 pm Would that sort of bracket and fitting pass any sort of current safety criteria? I'm not one of the 'elf 'n safety inn'it' gang, but dear o' deary me, that's a recipe for shredding a forehead and eye socket in an accident
None of the car would pass todays safety criteria so I don't see what difference it makes.
Hipwell
Post by Hipwell »
Don't think there was a safety requirement up until about 1965 when the mirrors had to be 'breakable' on impact i.e most of them became plastic.
The twin oblong hole mount is as fitted to Aston DB5/6.
111Robin
Post by 111Robin »
This mirror has the exact same collet type stem adaptor and screw hole spacing as mine so looks a likely source. This is Holdens but probably available elsewhere for less if anyone is looking for an adaptor. The screw spacing is 31mm so doesn't fit the three hole arrangement but possibly would fit earlier cars with the two hole mirror attachment ?. Another option on Ebay, 39mm hole spacing.
