Window filler strip
Window filler strip
Before removing my existing filler strip (black )with a chrome strip supplied by mMniSpares there is a difference in shape ,has anyone had a problem with this ?
- Nick W
Re: Window filler strip
First off, are you replacing your original? .if so DONT as the replacements that are available from any of the suppliers do not last very well, the strip of foil in them starts to crinkle.
But they are the same dimension and do fit ok.
Nick
Nick
Up North in Sheffield
- mk1coopers
Also, the ease of doing this will depend on if you have the right roller tool, and how old / stiff that rubber windscreen seal is...
Trust the stuff I supplied has lasted Nick
- Nick W
Yes of cause...I wasn't including your nos stuff in my comment
Good to hear NickNick W wrote: ↑Sat Sep 16, 2023 11:23 amYes of cause...I wasn't including your nos stuff in my comment![]()
They are what came with the car ,the seal is not stiff so probably not original based upon the picture it is clearly a different shape and larger
has anyone replaced with a similar strip?
