Rpm
Rpm
This might be kind of weird question or topic my car does not have a tachometer. My car is a complete stock 1275 Cooper S. I am wondering what is a good cruising speed on Highway. Measured in mph or kph and what RPMs would I be at? I've looked through books watched videos and can't seem to find anything for a safe cruising speed on Highway. Any information would be helpful please and thank you
- timmy201
Re: Rpm
Tachometers weren’t standard fitment on mk1 minis. On a Cooper S the maximum shift points are marked on the speedo with some Roman numerals - I, II, III
It should be happy to sit on 60-70mph all day which is around 4000rpm
- MiNiKiN
Re: Rpm
Here you find graphs for a Cooper S close ratio with 3.44 and 3.76 final drive. Speed on the Y-axis is in kphBLACKJACKф wrote: ↑Wed Sep 13, 2023 6:45 pm This might be kind of weird question or topic my car does not have a tachometer. My car is a complete stock 1275 Cooper S. I am wondering what is a good cruising speed on Highway. Measured in mph or kph and what RPMs would I be at? I've looked through books watched videos and can't seem to find anything for a safe cruising speed on Highway. Any information would be helpful please and thank you
If only I knew the power of the Dark Side...I wouldn't have made contact with an Innocenti
- Exminiman
Re: Rpm
here you go - you can try out different ratios, tyres etc...here
http://www.guess-works.com/Tech/ratio.htm
If you want to find out what ratio diff you have this is as good a description as I have seen of what to do https://www.theminiforum.co.uk/forums/t ... ?p=2107153
- BAD942B
Re: Rpm
And here is kmh to mph converter https://www.unitconverters.net/speed/kph-to-mph.htm
Chris A
Re: Rpm
Okay thank you so much that information. Is the engine very reliable at 4000 RPM? It is 55 years old . Lol I do know about the three orange colored lines on the speedometer I have never come close to an RPM that high . So maybe I should change my final drive to a 3.1
Re: Rpm
Yes I understand that about swapping to a 3.1. Thanks for the information again. Jack.
