I have a DAM2886 rod box to build towards the end of the year - casings have just been sent away for vapour blasting and will be assembled with genuine metal race bearings throughout, new bushes, n.o.s Leyland baulk rings, 3step comp layshaft, centre pick up etc..
Correct and rare DAM3168/DAM3167 close ratio gear set, these were fitted to to last of the GTs 1979-81, pot joint outputs and a final drive 3.44 or a choice from (2.76 to 4.1)
Can also be supplied with correct transfer case, idler gear, primary gear and gasket. The idler gear will be shimmed to tolerance.
Photos of the build can also be provided.
If there is any interest, let me know with your final drive requirement along with standard cast cage or x-pin and I will list in the correct ‘for sale’ section with a price.
Regards Jason
