URGENT HELP NEEDED - Swiss/German/French border area.
gs.davies
Post by gs.davies »
Afternoon all. Day two of the run down to IMM and we’ve developed a bearing noise.
We are suspecting diff or gearbox main bearing.
Does anyone know of anybody in the Swiss/German/French border area that could help?
phil82
Re: URGENT HELP NEEDED - Swiss/German/French border area.
Post by phil82 »
I‘m Just north of Stuttgart. What do you have on your mind? Check? Fix? Park until Return?
Cheers Philipp
phil82
Post by phil82 »
gs.davies
Post by gs.davies »
Ok we pressed on gently and nursed it to overnight stop at aSchwendelberg just south of Lucerne.
We jacked up the front and ruled out wheel bearings so probably diff bearings or main gearbox bearing.
gs.davies
Post by gs.davies »
phil82 wrote: Wed May 24, 2023 4:55 pm I‘m Just north of Stuttgart. What do you have on your mind? Check? Fix? Park until Return?
Cheers Philipp
All of those to be honest.
We think that it’s most likely to be diff as there’s no problems with gear selection suggesting the mainshaft is still located ok.
Whilst I used good secondhand main roller, the diff bearings were reused from the 850 so my money is on diff bearings.
Happy to have the job done by someone who knows what they’re doing and can get the right parts and be a day late to IMM.
Catmint
Post by Catmint »
Gary, Automobiles BMC at Lyon may be able to help if you are that way
https://www.auto-bmc.com
hanlminiman
Post by hanlminiman »
Try Facebook French pages - Dominique Sabat who is near Frejus but has many contacts within the Mini community in France. As well as Automobile BMC who may have contacts in your location.
mini1960
Post by mini1960 »
Hi,
I have asked a guy from Mini Club Luzern for a recommendation. As soon as I get details I will let you know.
Daniel
Looking for Morris Mini Minor 1960 parts... (master brake and clutch cylinder, lower dashtray panel)
gs.davies
Post by gs.davies »
mini1960 wrote: Wed May 24, 2023 9:12 pm Hi,
Daniel
Thank you so much!
mini1960
Post by mini1960 »
Hi Gary,
his recommendation was also www.nicksgarage.ch or Rolf Bosch from www.minifun.ch.
Both are Mini specialists. Hope you get it managed!
Daniel
