Under bonnet insulation, worth doing?
snoopy64
Has thanked: 93 times
Been thanked: 14 times
Post by snoopy64 »
Hi
Is it worth putting under bonnet insulation on?
Kevin
Kevin
rolesyboy
Has thanked: 19 times
Re: Under bonnet insulation, worth doing?
Post by rolesyboy »
Just glued mine on this week. Never had it before.
Will let you know after the weekend. I know the bulkhead piece made a huge difference
Still feckin noisy though. But I love it :D
snoopy64
Post by snoopy64 »
Good timing!, feedback much appreciated
Kevin
Has thanked: 150 times
Been thanked: 137 times
Yep, still noisy but it does stop the drumming effect
snoopy64
Post by snoopy64 »
rolesyboy wrote: Fri Mar 10, 2023 5:42 pm Just glued mine on this week. Never had it before.
Which type have you used? How many pieces?
Kevin
rolesyboy
Post by rolesyboy »
Just the Minispares hardura type stuff in triangles.
You can’t get the preformed original stuff anymore
I’ve got one but it’s going on my next car
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
My Minispares Insulation didn't even last one Day.
I am still on the search of the real thing...
Look at this older tread...
http://mk1-forum.net/viewtopic.php?f=5& ... on#p300095
Edit: i was informed that Minispares now sorted out the faulty Material and now haven't amy issue's.
rolesyboy
Post by rolesyboy »
Ooh ‘eck . In fairness it looks pretty resilient stuff. What went wrong?
MS did have a shockingly bad batch a while ago, this just fell apart within minutes of being fitted. This issue has now been resolved.
InnoCooperExport
Has thanked: 4 times
Been thanked: 11 times
Post by InnoCooperExport »
mk1 wrote: Mon Mar 13, 2023 8:42 am MS did have a shockingly bad batch a while ago, this just fell apart within minutes of being fitted. This issue has now been resolved.
That explains mine then! I pulled mine from last year out of storage to look into fitting it when the temperatures come up (my spray glue requires it to be at least 16 degrees C) only to find the black material was seperating from the backing already. Thinking I'll have to peel it all off and reglue it properly before trying to fit it to the bonnet.
Yup, that was the issue. As I say, now sorted.
Bitsilly
Post by Bitsilly »
If it is the drumming noise you want to get rid of, I would guess it may be best to use self adhesive bitumen based sheets. Like Dynomat.
Then you could put it on the inside rather than the engine bay.
You will learn to love the stuff!
I reckon the triangular sound deadening under the bonnet ois well worth doing. I does cut down on the noise & it also gives the bonnet a good weighty feel.
I have it on nearly all my cars.
Joel Welsh 4769VU
Post by Joel Welsh 4769VU »
If its not an originality thing- would something like dynamat work with the sound deadening situation? It's what it's made for, and pretty durable stuff... just not cheap.
https://www.dynamat.com
Wauseon, Ohio- United States
Tartan red and black
I can't take credit for what others built- all I can do is try to put her back on the road. :shock:
You just can't fix stupid... you can hide it sometimes though... :lol:
MiNiKiN
Been thanked: 31 times
Post by MiNiKiN »
Joel Welsh 4769VU wrote: Wed Mar 15, 2023 3:49 am If its not an originality thing- would something like dynamat work with the sound deadening situation? It's what it's made for, and pretty durable stuff... just not cheap.
Here is a cheaper alternative to Dynamat
They offer both: Butyl- and felt based insulation.
https://www.heatshieldings.com/en/sound-insulation/
Exminiman
Has thanked: 58 times
Been thanked: 57 times
Post by Exminiman »
For max sound deadening, combination of anti drum pads and sound insulation might work well ?
snoopy64
Post by snoopy64 »
Update on the Minispares bonnet triangles… they still fall apart after the first run up the road!!!
Kevin
rolesyboy
Post by rolesyboy »
That’s odd. I put mine on and have done 800 miles since. No problem and no signs of fatigue at all.
whistler
Has thanked: 18 times
Post by whistler »
Just fitted the Minispares kit under the bonnet of my Mk1. Had to chop all 4 pieces to make them fit. Very poor Minispares.
snoopy64 wrote: Thu Apr 20, 2023 5:28 pm Update on the Minispares bonnet triangles… they still fall apart after the first run up the road!!!
Oh Great!
I had been assured that they had chucked all the duff stuff out & replaced it with original hardura.
