Single to Twin SU Worth It?
I have an '88 Mini with a 1275cc engine, unknown internal mods (maybe a hot cam as some local Mini mechanics suggested). Has a single HSU4 carb with stock manifold and K&N gauze intake filter.
Is there much to be gained by converting to a twin SU setup? If so, what carb size should I be looking for?
Thanks.
Thanks.
- timmy201
Re: Single to Twin SU Worth It?
Depending on the modifications to the engine you might be better off with a single 1.75” carb
If you wanted twin SU carbs then for a relatively tame engine you’d pick twin 1.25” carbs, and for highly tuned 1275 engines you’d pick twin 1.5” carbs
Regardless of the direction you chose, you need to have good condition carbs that are matched, built correctly and tuned for the performance of your particular engine
- Exminiman
Suppose question is what do you want to use the car for…..fast road, competition ?
If its road? and you are not concerned about every last HP, then I would stick with the single SU and a decent manifold
Single SU is smoother, easier to set up………….and cheaper
- johnv
But twins look soooo much better...
Mk2 1968 Cooper 998
Mk1 1965 Cooper 1275
Mk3 1971 Cooper S
Mk2 1968 Moke
Mk3 1971 Cooper S
Mk2 1968 Moke
Ya not looking for top power and performance. It is a street car to ride about in for fun.Exminiman wrote: ↑Thu Mar 02, 2023 6:39 am Suppose question is what do you want to use the car for…..fast road, competition ?
Single SU is smoother, easier to set up………….and cheaper![]()
I have a classic motorcycle that I converted from single to dual carb and found bike much more lively in mid range, so got me thinking the cooper S setups might be worthwhile. I use a dual vacuum guage setup to balance my bike carbs and a colortune to help with setting mixture. Are these used on dual carb mini tunes?
For your use I would suggest single HIF 44 on good inlet with proper air filter. Once that is sorted get it set up on a rolling road by someone who knows about SUs.
- mk1
Couldn't agree more with Cheeser.
The HIF44 is a very good carb & you are unlikely to be able to detect any improvement using twin HS2's over an HIF44 on a decent manifold. The single is cheaper, easier & will stay in tune longer.
If all you are bothered about is decent reliable performance, then the HIF is the way to go, if you want something that goes about the same but looks much "cooler" then twins is a great option. But they will cost more than twice as much be less reliable & will certainly go off tune fairly frequently.
As ha salso been said, whatever option you go for an initial dyno session is essential.
- UHR850
I had a Hif44 carb on my MG Metro engine but changed it to a twin Hs2 setup. I was not happy with that so did put the Hif44 back on it, happy again.
I am like you Tornado. I use a colourtune to set my mixtures. but I use my sensitive ears and stethescope to set the air intake.
Nothing wrong with a refurbished - or known good - HIF44
What is your classic bike? Me too......
- tweedy998
I'd probably echo what others have said and in your case suggest sticking with a single, probably a HIF 44.
Twins do look very aesthetically pleasing, but do need quite a lot of things to be right, are quite high maintenance and expensive, as others have highlighted.
1965 Tweed Grey Mk1 Morris Cooper 998
2005 Renaultsport Clio 182 Trophy 407/500
2010 Storm Grey Renaultsport Clio 200 Cup
