1. Did they have any stick on trim fitted onto the Dash Top Tail + the Inner A posts + Dash Cross Member ?
2. What spec; should the 12v Battery be & also what are the battery dimensions ?
3. How should this Pickup 12v Battery be secured & does the battery stand in a plastic Tray ?
4. On this Pickup shell looking on the Inner left side heel board there is an odd shape bracket located on the heel board inner vertical face ? .. so asking what appears to be original build angular bracket for ? .. all it appears to be doing is stopping the spare wheel pushing fully back under the floor into its stowage?
I am rebuilding this Pickup for a Friend who wants wide wheels so will require Wheel Spats
5. Is there a UK Supplier of Pickup suitable front & rear wheel arch extensions ?
Thanks for your help.
