Digital Speedo
Polarsilver
Digital Speedo
Post by Polarsilver »
Only asking :oops:
Re: Digital Speedo
The full range of Smiths classic Mini digital speedos (£375) :-
https://www.digital-speedos.co.uk/gauge ... h-mini-t40
timmy201
Re: Digital Speedo
Post by timmy201 »
My friend had one on his mini and it worked great. Easy to calibrate, accurate and smooth needle & no big speedo cable.
The backlit odometer/trip is the most obvious giveaway that it's electronic, apart from that it looks really nice
Tim
Re: Digital Speedo
Post by Tim »
I'm making my own for the Moke. It will use the original mechanical odometer and needle turned by stepper motors. From the outside it should look identical to the original, apart from being correctly calibrated.
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Polarsilver
Re: Digital Speedo
That idea seems a good solution .. clearly i do not know what i am talking about when asking would step motors be reliable on rough roading such as you have in Australia.?
Re: Digital Speedo
I am sure that a stepper would be more reliable than an old fashioned spring balance movement.
Tim
Re: Digital Speedo
Post by Tim »
Most modern vehicles have stepper motor driven instruments. For the needles they generally have something like one of these little guys behind each needle.
They aren't very powerful, but have a tiny plastic gearbox inside them so they are able to hold a needle in position no-worries.
Driving the odometer is a bit more complicated. I'm using one of these. Image
They are tiny, but again, because they are geared they have a decent amount of torque. You can get them in a range of gear ratios. I've found a small brass unversal joint that allows me to couple the shaft from the motor to the end of the odometer shaft. It looks like it will work OK.
I'll control it all with an Arduino microcontroller and the speedo signal will come from a GSD1000 - MiniSpares electronic speedo drive adaptor.
If anyone is interested in a basic primer, this bloke (who I stole the image at the top from) is excellent. https://guy.carpenter.id.au/gaugette/20 ... -gaugette/
Tim
1955 BSA C11G
1969 Triumph TR6R
Re: Digital Speedo
Thanks Tim, Thats really interesting!
Festus
Re: Digital Speedo
Post by Festus »
Hello and thank you @Tim for sharing. It is indeed very interesting.
My website here
Re: Digital Speedo
I went Digital in my Moke about 12 years ago and never looked back. I've since built a few more similar Mokes and now Smith do a special Range of Instruments to my specs to suit these cars. I can't ever see myself going to a mechanical unit ever again. I've just started making Mini / Moke specific Senders to go with them.
