Special tuning H4 carbs
- mk1
Re: Special tuning H4 carbs
The throttle cable bracket is available from the likes of Minispares.
- johnv
This one
http://www.minispares.com/product/Class ... 0to%20shop
I must have something else wrong then as that one doesn't have the right angles
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
- Ronnie
Those ebay carb's they appear to have an odd set of pistons one appears to have been flowed and the other is standard.AndyPen wrote: ↑Thu Nov 17, 2022 5:21 pm This ad seems to be pretty much what my sets look like - hope it helps? I see the two spring extensions in your box of bits.
https://www.ebay.co.uk/itm/295339019106 ... gKpSvD_BwE
Oh yeah - looks that way - well spotted!Ronnie wrote: ↑Fri Nov 18, 2022 11:17 amThose ebay carb's they appear to have an odd set of pistons one appears to have been flowed and the other is standard.AndyPen wrote: ↑Thu Nov 17, 2022 5:21 pm This ad seems to be pretty much what my sets look like - hope it helps? I see the two spring extensions in your box of bits.
https://www.ebay.co.uk/itm/295339019106 ... gKpSvD_BwE![]()
Are these the correct float bowls for the carb tags listed. Finally pulled everything out of the cleaner and can now read the part numbers on the castings.
- TECH396
Nick. I believe the correct number is AUC4814 and they would use 2 of the RH floats for the LHD setup. The other float is AUD4815 & also 30deg.NicholasUpton wrote: ↑Fri Nov 18, 2022 5:43 pm Are these the correct float bowls for the carb tags listed. Finally pulled everything out of the cleaner and can now read the part numbers on the castings.
Paul H.
I assume they are correct, no AUC but cast with 4814
[/quote]
[/quote]
- TECH396
[/quote]NicholasUpton wrote: ↑Fri Nov 18, 2022 6:21 pm I assume they are correct, no AUC but cast with 4814Nick. I believe the correct number is AUC4814 and they would use 2 of the RH floats for the LHD setup. The other float is AUD4815 & also 30deg.
Yup, those are them. You can see they're 30deg and not the more common 20deg ones. The omission of the "AUC" may be reproduction ones?. (Burlen sell some), but I'm not 100% sure. I'm sure someone else here can confirm that..
Paul H.
They are original SU bowls not burlen ones .
The most difficult item to find to build up a set of H4,s with 30 degree bowels
- timmy201
My 4814 is cast with the number only and no “AUC”
But the 4815 is cast with AUC
