Actual 998 Chat about rebuilds
snoopy64
Re: Actually a General Chat about rebuilds
Post by snoopy64 »
[quote="251 ENG" post_id=311210 time=1666201886 user_id=
Biggest problem with 998 cooper is D top piston availability, new oversize ones are incredibly rare .
You can use flat top pistons but that means you have to take a big chunk off head .
You can also modify flat top pistons to D tops but then you have to take a chunk off block
[/quote]
No easy option then :D
Kevin
12345678
Post by 12345678 »
Pardon my ignorance, but wouldn’t 998 d top rings be the same as standard 998 rings? Aren’t those readily available?
timmy201
Post by timmy201 »
The rings might be easier to find, but if you’ve only got standard size pistons and the cylinders need a rebore then new rings won’t help
snoopy64
Post by snoopy64 »
998 cooper ring std size from 1970 workshop manual
Kevin
snoopy64
Post by snoopy64 »
So, I thought I read you can’t fit a vernier duplex timing set to a pre A plus 998, but I’m sure it’s been done…any experience?
Also, can you/ should you re finish the pads on pressed rocker arms?
Kevin
timmy201
Post by timmy201 »
I put a duplex set on my pre A+ 1098 which is essentially the same as a 998. I didn’t use the adjustable gears as I didn’t want an extra place for something to go wrong so I used an offset woodruff key
I also had the pads on the rockers refinished and after a couple of years and maybe 10,000km there’s now some visible witness marks but no wear on the pads.
snoopy64
Post by snoopy64 »
Hi, thanks for the info, especially ref the rocker pads..
Kevin
johnv
Post by johnv »
snoopy64 wrote: Tue Oct 25, 2022 7:32 pm So, I thought I read you can’t fit a vernier duplex timing set to a pre A plus 998, but I’m sure it’s been done…any experience?
you just need to countersink the 2 screws under the cam pulley
Mk2 1968 Cooper 998
Mk1 1965 Cooper 1275
Mk3 1971 Cooper S
Mk2 1968 Moke
snoopy64
Post by snoopy64 »
Thanks for confirming…
Kevin
snoopy64
Post by snoopy64 »
Just looking now to salvage the pressed rockers, if the pads will dress up it’ll be a bonus.. :D
Kevin
