Actual 998 Chat about rebuilds
snoopy64
Has thanked: 93 times
Been thanked: 14 times
Post by snoopy64 »
Hi
I’m looking to have an actual chat (on the phone!) with anyone who can give me advice on getting my Cooper engine rebuilt, questions to ask the rebuilder, choosing a company etc any personal experience and the million dollar (almost) question , should I even do it?
pm me if you can help
Kevin
Kevin
Has thanked: 150 times
Been thanked: 137 times
Re: Actually a General Chat about rebuilds
That's a good lead-in to another question that maybe Kevin might like to consider. Has anyone had any dealings with local Oxford firm OSELLI recently?
woodypup59
Has thanked: 9 times
Been thanked: 23 times
Post by woodypup59 »
Many people seem to be be happy with SMMT (Southam) who are now at Napton, nr Daventry, but before that I guess you need to know what you want.
I guess you have a 998 Copper. Do you want to keep it stock, or are you looking for a lot more power ?
snoopy64
Post by snoopy64 »
Just a stock short engine rebuild..
Kevin
johnv
Post by johnv »
You're in Berkshire? Bracknell Classic and Modern Engines would be a good starting point
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
snoopy64
Post by snoopy64 »
Hi there
Not the first time they’ve been mentioned.. :)
Kevin
snoopy64
Post by snoopy64 »
Thanks everyone for your advice etc. Well its started... is that Marmite or Bovril though??
Kevin
WMU 211G
Has thanked: 30 times
Been thanked: 30 times
Post by WMU 211G »
It's space dust mate... where exactly have you been driving it...? :lol:
1968 Mk2 Morris Cooper
I have seen MUCH worse.
Roadrunner
Post by Roadrunner »
Peter Laidler wrote: Mon Oct 03, 2022 10:57 am That's a good lead-in to another question that maybe Kevin might like to consider. Has anyone had any dealings with local Oxford firm OSELLI recently?
Your having a laugh there, I only ever used them for machining ie re-bore and balancing I preferred to build my own. I did then Richard Walker worth using though he used to work there before setting up on his own but I see now his company was purchased by some one else. Last engine I built I got as a kit from MED only because I happened to be working nearby. Osselli was an Oxford Based Firm that was in Eyensham when I first went there then moved to Osney Mead. It's not in Oxford any more.
I just looked at the manual when I did my first rebuild and I can send a PDF of it if you need one.
snoopy64
Post by snoopy64 »
WMU 211G wrote: Wed Oct 19, 2022 3:57 pm It's space dust mate... where exactly have you been driving it...? :lol:
The previous owner ruined it, thought he was driving a train :lol:
Kevin
Roadrunner
As you have West Berks where you come from you could have a word with https://h-dev.co.uk/ for some advice not they look to me mainly remapping though but they are at Chieveley
Are you saying (previous page) that Oselli are crap - or that you are better - or what exactly......?
snoopy64
Post by snoopy64 »
mk1 wrote: Wed Oct 19, 2022 4:08 pm I have seen MUCH worse.
Thank goodness, I think!!
Kevin
Roadrunner
Peter Laidler wrote: Wed Oct 19, 2022 6:11 pm Are you saying (previous page) that Oselli are crap - or that you are better - or what exactly......?
No when I was younger I heard some bad vibes about them and building an engine yourself is easy enough if you have the gear or knowledge. One of my friends had his S engine rebuilt by them and it ran OK but they are not the old firm I knew when it was in Osney and I worked round the corner. I would not put them down I'm sure a lot of people are happy with the work they do but you will always find problems. I must admit the work they did for me when I had a problem with a gearbox in my GT was spot on. What I meant are having a laugh is I did not think they were still operating seems they are
WMU 211G
Post by WMU 211G »
snoopy64 wrote: Wed Oct 19, 2022 5:02 pm
Notch eight, don't be late...! :D
Just bore the blighter out to 1380 and have done with it Kev!
251 ENG
Post by 251 ENG »
Southam mini metro centre SMMC 01926 815681
BUT
Got 40+ engines in a moment so be prepared to join que
Biggest problem with 998 cooper is D top piston availability, new oversize ones are incredibly rare .
You can use flat top pistons but that means you have to take a big chunk off head .
You can also modify flat top pistons to D tops but then you have to take a chunk off block
snoopy64
Post by snoopy64 »
Plenty to think about…
Kevin
hanlminiman
Has thanked: 21 times
Been thanked: 37 times
Post by hanlminiman »
Sent you a pm.
Cliff
Can't get much better than those Compression readings!
