Timeing cover oil seal Q
Polarsilver
Post by Polarsilver »
Having a problem with the Timeing Cover Oil Seal its Leaking ..its new supplied along with the new Crank Pully both from our favourite supplier.. so its crank seal out again and i will check dimension of the Crank Pulley outer dia; of the shaft ref; the working surface to the Oil Seal.. my question is who supply the "Best" Timeing Cover Oil Seal as i seem to be suffering issues given this oil seal is new running on a new surface and fitted correctly. :?:
Re: Timeing cover oil seal Q
I have not had any issues with these for many years. The trick is to make sure the pulley & seal are centred before tightening the bolts up. If you fit the cover then the pulley, the two can be misaligned allowing oil to leak out from the misaligned seal.
You can do this by fitting the gasket to the front plate, I use a bit of gasket goo (but NOT MUCH), then I goo the timing cover, just place it over the end of the crank & gently seat it on the gasket, then slide the pulley on, once that's all in position, I carefully fit all the bolts making sure I tighten them a bit at a time all around, like you would the nuts on a cylinder head. Once the cover is tightened up I remove the pulley, put a little Graphogen on the oil seal & then fit the pulley permanently.
Seems to work OK for me.
General dogsbody.
Agree with Mark, Norman (good to see you on Sunday too.....) The important bit is centralising the pulley within the seal fitted to the cover. If that means jiggling the cover to suit, then so be it.
There is (was) a tool for centering the seal to the crank. I made mine from an S Pulley;-
You can usually get good results though from using the Pulley as Mark has suggested.
Check too that the seal shaft on the pulley isn't grooved and grease between the lips on the seal.
Polarsilver
On Inspection of Timeing Cover Oil Seal.. you will be aware the inside of that Oil Seal has a back up spring .. that spring was just slack and not doing the job intended.
Exminiman
Post by Exminiman »
mk1 wrote: Thu Jun 16, 2022 1:45 pm Once the cover is tightened up I remove the pulley, put a little Graphogen on the oil seal & then fit the pulley permanently.
So you find that Graphogen helps between the shaft and seal, presumably to lube the lip until oil gets there ?
Yes, I reckon a smear of Graphogen help lubricate everything until oil makes it's way there.
I too have the tool, but the method above works fine.
General dogsbody.
