WTH??!?! Have you seen this item on ebay.
- mab01uk
Re: WTH??!?! Have you seen this item on ebay.
1973 Austin Mini 1275GT Body Shell With V5
https://www.ebay.co.uk/itm/155792811893 ... R9azhMfZYg
Nice easy (?) mini project for a relatively new beginner I'd say. Apart from the scuttle panel and what you'll find underneath that.....!
Hmm, can't help but think the title should be "1973 Austin Mini 1275GT V5 with a (random clubman) bodyshell"
Check out the single tower bolts, the transmission tunnel and the roof gutter
It`s clearly a MK4 shell
- mab01uk
How To Spot A Mk3 (Oct '69- '76) Mini Saloon Shell:-
https://www.theminiforum.co.uk/forums/t ... oon-shell/
- Exminiman
Interesting, potential to be made 4wd, modify it as you like, DVLA have nothing to compare it against
- MiNiKiN
Honey I shrunk our Land Rover!
If only I knew the power of the Dark Side...I wouldn't have made contact with an Innocenti
- whistler
I had a L reg 73 clubman and the tunnel looked just like that. I think the clubman changed to rod change in late 72.
The tower bolt is definitely a wrong 'un. Think they were twin bolt subframes until about 76.
