6x10 JA Pearce Magna wheels with Spinners + arches?
WMU 211G
Has thanked: 30 times
Been thanked: 34 times
Re: 6x10 JA Pearce Magna wheels with Spinners + arches?
Post by WMU 211G »
I'm quite tempted actually.... might have to get myself a bigger paper round first though... ;)
1968 Mk2 Morris Cooper
Quinny1293
Post by Quinny1293 »
I Managed to recently find a set of 3 JA Pearce wheels in 12 inch. Hoping to have them by end of the week and then was lucky enough to find a 4th one with a friend I knew that used it as a display unit.
Apparently they are 7J, so not sure what 12 inch tyres will fit nicely over them. I suspect it was used on a race car back in the 60’s or 70’s, on a mini known as the “Pitco Quickie Mini”
1969 Mini Cooper S Mk2
1971 Mini 1275 GT
1979 Mini 1275 GTS
Wayne 962
Post by Wayne 962 »
Hi everyone. I'm still looking for a set of 12" and 15" J A Pearce wheels. Actually, I already have three 12" wheels and three 15" wheels, so I would only need one of each.
Long story, it's for this car: https://dempseymotorsports.com/m-505-ad ... -probe-16/
Thx,
Wayne
wayne@dempseymotorsports.com
IanD1965
Post by IanD1965 »
Here’s another example of a small production alloy from Mamba wheels . Have a set of four that came with my Minijem hillclimb car 35 years ago. The seller asked me if I wanted the Mamba wheels for an extra few quid. They are 6.75” x 10”
The racing mini book by John Baggott makes reference to them on the 2 cyl BDA mini .
Looking for a spare if anyone has one ?
IanD1965
Post by IanD1965 »
Here’s the images of the wheels in use. Peter Day, Andy Barton and the text from Baggott Book
BigWig
Post by BigWig »
IanD1965 wrote: Sat Jul 20, 2024 6:05 pm Here’s another example of a small production alloy from Mamba wheels . Have a set of four that came with my Minijem hillclimb car 35 years ago. The seller asked me if I wanted the Mamba wheels for an extra few quid. They are 6.75” x 10”
I have a set of these that my car ran in period during its special saloon days / Free Formula 850. Interesting read, I was told they were an early Revolution. Can’t say I have seen another set!
Vegard
Post by Vegard »
Quinny1293 wrote: Sun Mar 12, 2023 3:50 pm I Managed to recently find a set of 3 JA Pearce wheels in 12 inch. Hoping to have them by end of the week and then was lucky enough to find a 4th one with a friend I knew that used it as a display unit.
I use regular 165/55-12 Yokos on my 7x12 Minilites on my race car. No problems.
dazza
Post by dazza »
Only just seen this topic the back mini with magna is owned by me and was built by myself and my father.
Has thanked: 150 times
Been thanked: 137 times
While the JAP's and spinners always looked good....... A bit like a mickey mouse watch looks good* - I've always been a bit doubtful about the mechanicals and geometry of such offsets on standard axle shafts, drums and especially bearings, even taper rollers. The extra leverage on the axle components worries me because the extra leverage exerted isn't on a linear or straight scale, it's more of a curved or logarithmic scale (wrong word ?). OK for a racer where things are stresed to the Nth degree but stripped and inspected every other race. But a road car with your average not-too mechanically-minded owner driver, then I'm not sure.
I wonder what 1071 Bob or Spider Chris thinks
* Mickey mouse watch. Looks good but not so good when it comes to telling the time
Old proverb
Has thanked: 262 times
Been thanked: 231 times
Peter Laidler wrote: Sat Nov 02, 2024 12:32 pm While the JAP's and spinners always looked good....... A bit like a mickey mouse watch looks good* - I've always been a bit doubtful about the mechanicals and geometry of such offsets on standard axle shafts, drums and especially bearings, even taper rollers. The extra leverage on the axle components worries me because the extra leverage exerted isn't on a linear or straight scale, it's more of a curved or logarithmic scale (wrong word ?). OK for a racer where things are stresed to the Nth degree but stripped and inspected every other race. But a road car with your average not-too mechanically-minded owner driver, then I'm not sure.
Old proverb
The factory produced the MPi Mini for the roads with much heavier 6 x 13" rims and 175/50 x 13 tyres and really just fitted uprated shock absorbers/dampers, so I doubt there is any significant difference to a Mini on the JA Pearce 6 x 10" rims and 165/70 x 10 tyres which probably weigh less...
I do remember an MOT tester saying MPi Minis often needed balljoints adjusting or replacing to pass, because the Rover Main Dealer mechanics no longer had much idea how to service and maintain such an old design and did not even possess a grease gun! :lol:
dazza
Post by dazza »
The wheels have been on the car for over 10 years on the same wheel bearings and no issues.
Keith Calver has an interesting 'Technical Info' article on his website about the effects of bigger wheel/tyre combinations. (Extract below and a link to the full article).
Wheels & tyres - Bigger wheel fitment consideration - Keith Calver.
"There are a number of things that need serious consideration no matter which wheel/tyre combination you decide to go for.
First and foremost is suspension and steering component condition. The original 10-inch combination is relatively 'forgiving' - masking slight component wear simply because it has relatively low leverage effects and dynamics as a whole. This encompasses everything affected by wheel/tyre weight and profile and the grip afforded by the tyre contact patch on the road. Wheel/tyre weight affects damper performance - their ability to keep the tyre in contact with the road surface the main issue. It also affects acceleration and deceleration generated by the 'flywheel effect' and steering by the 'gyroscope' effect. Tyre profile affects ride, comfort, handling and grip.
All these conspire to exaggerate any shortcomings in the suspension and steering components. Slightly worn swivel pins, top arm bearings, bottom arm and tie-rod bushes, track-rod ends, steering rack, and wheel bearings will become very worn in a very short space of time. Tired dampers will not be able to keep the wheel/tyre in contact with the road. This can be dangerous - it will adversely affect safety, as you are completely reliant on those four small tyre contact patches whatever you do in a car. If the tyre isn't in contact with the road surface, you can't steer, stop, or go. As outlined earlier - a situation made very much more difficult in a Mini (or any front-wheel drive car) as it's all going on at the same end at the same time. Lower profile tyres have less flexible tyre walls - affecting ride quality (making it bumpier), and less compliant (will follow all ripples, bumps and cracks in the road surface). Although it has to be said that a number of modern sports cars have huge wheel/tyre set-ups to not only increase grip - the larger over-all circumference 'bridges' some bumps/holes, thus 'smoothing' the ride out by reducing/eliminating some of the smaller bumps.
Wider tyres will usually increase grip that will apply greater leverage against all the suspension locating bushes and bearings. Any that are worn will cause the increased leverage to push and pull the suspension into unwanted positions/angles. The result is a wayward car that doesn't handle well - seemingly developing a mind of it's own at inopportune moments if not all the time. The more grip the tyre develops, the easier it is for it to overcome the braking capability of the set-up on your car - the extra leverage applied by the bigger over-all diameter worsening the situation.
Up-rated dampers are a must. The standard items are barely capable of dealing with the standard set-up when brand new (a nod in the direction of 'comfort' by the OE manufacturers) let alone when worn. Bigger wheels/tyres means more (un-sprung) weight to control when encountering road surface imperfections (bumps/pot-holes). The barest minimum should be 20% up-rated standard-type dampers. Personally I would only recommend starting at Kayaba 'Gas-A-Just' dampers (my current preferred type for cost/performance and fit), if not going to one of the adjustable sports types.
The message here then is to make sure your whole suspension is in first class condition before contemplating the change. This is an ideal opportunity to fit up-rated components if worn bushes need replacing. Up-rated bushes offer greater resilience in both wear and movement, which will help provide greater suspension location and control when a bigger wheel/tyre combination is fitted. Essential to maintain the good 'handling' aspects believed to be endowed by the Mini's original design. And make sure your braking system is capable of dealing with your wheel/tyre choice."
https://www.calverst.com/technical-info ... ideration/
CCC magazine 1968
