Actual 998 Chat about rebuilds
251 ENG
Re: Actually a General Chat about rebuilds
Post by 251 ENG »
Toby has a NOS set of D top pistons for sale to suit STD bore
snoopy64
Has thanked: 93 times
Been thanked: 14 times
Re: Actual 998 Chat about rebuilds
Post by snoopy64 »
Good shout, thanks
Kevin
snoopy64
Post by snoopy64 »
Ok, bores checked now… quite a bad taper …
Kevin
snoopy64
Post by snoopy64 »
So, what is the downside to sleeving/fitting liners in a block???
Kevin
Thorp
Post by Thorp »
Simple answer is cost, but no downside on a road engine really.
snoopy64
Post by snoopy64 »
Thorp wrote: Mon Nov 14, 2022 5:23 pm Simple answer is cost, but no downside on a road engine really.
I presume you mean compared with a bore out plus new pistons…?
Kevin
OzOAP
Been thanked: 12 times
Post by OzOAP »
johnv wrote: Wed Oct 26, 2022 9:56 am you just need to countersink the 2 screws under the cam pulley
Crank pulley.
I would measure cc in head chamber and measure head deck thickness to the oil drilling. Then you'll have an idea on how to achieve required comp ratio.
D-Top, Flat-top, deck head, deck block......
snoopy64
Post by snoopy64 »
Ok, machining all sorted, now +20.
Can anyone recommend a cam close to std and is it worth fitting a duplex timing setup?
Kevin
Polarsilver
Has thanked: 38 times
Been thanked: 55 times
Post by Polarsilver »
Minispares Evo 1 Cam is good value for the money. just a matter of what type Rockers are used & what do you want from your engine.
Another vote for the evo 1 or alternatively Calvers CST229 is a good bet too.
Personally I put duplex's on all my engines, not sure whether it's really necessary though.
Has thanked: 150 times
Been thanked: 137 times
Yes, Duplex...... peace of mind I say
Costafortune
Has thanked: 36 times
Been thanked: 38 times
Post by Costafortune »
Duplex chains are heavier and require more effort to rotate.
A good simplex chain is perfectly fine.
I believe that Swifty uses simplex chains on all his engines nowadays.
Richspec
Post by Richspec »
mk1 wrote: Tue Jan 17, 2023 2:53 pm I believe that Swifty uses simplex chains on all his engines nowadays.
if i was building a race engine I'd go highest quality single i could find, rotational losses and all that...
But for everyday longevity and not chasing every HP i use duplex as default.
snoopy64
Post by snoopy64 »
Hi,
thanks for all the supplies, I'm not looking to vastly improve anything, just a std set up with std rockers...
Kevin
Costafortune
Simplex JWIS chain. Has an A Series timing chain ever snapped? I've seen them so shagged they've worn through the timing cover, but never broken.
snoopy64
Post by snoopy64 »
Vernier gear worth it?
Kevin
timmy201
Been thanked: 42 times
Post by timmy201 »
I prefer using an offset woodruff key. The vernier adds an extra level of complexity that can come loose
There’s also the type with extra key ways on the crank sprocket to dial it in
https://outlawspeed.com.au/shop/cs8000
Costafortune
It's absolutely worth timing the camshaft in properly as well as having a good distributor built with a correct advance curve. You can lose 10 bhp with ease if they aren't right.
That and bumping up the compression ratio to 9.75:1 to run on super unleaded will really give it some sparkle. A good standard 998 Cooper was only a couple seconds slower to 80 mph than a 1071 S.
snoopy64
Post by snoopy64 »
mk1 wrote: Tue Jan 17, 2023 1:40 pm Another vote for the evo 1 or alternatively Calvers CST229 is a good bet too.
997 type cam isn’t quite the same as the 998 so will the dizzy need re curving?
Please excuse my ignorance!
Kevin
