Magnum alloy bonnet skin
Re: Magnum alloy bonnet skin
Received mine & I'm very pleased indeed. I have been told that there is no chance of them doing the inners though :(
Nick W
Post by Nick W »
Just us a steel frame and fill it with speedo holes ;)
Up North in Sheffield
That's the plan, then find some kind soul to paint it for me of course :lol: :lol:
Nick W
Post by Nick W »
Haha who might that be...
Hope you saved some paint for it
I wonder, Now let me think. . . . . :lol: :lol:
lomin
Post by lomin »
Hi, my OBL45F restoration is being done in epoxy two pak. The base sealer for the steel shell is a different product to what seals the aluminium panels. Apparently corrosion can occur under the paint if you do not use the correct aluminium one. The body shop was not aware of that, it was a paint manufacturer who pointed it out. The car should be painted in a couple of weeks. cheers Lindsay
Would love to see some pictures of that!
Ronnie
Has thanked: 13 times
Been thanked: 35 times
Post by Ronnie »
lomin wrote: Thu Jul 28, 2022 11:07 pm Hi, my OBL45F restoration is being done in epoxy two pak. The base sealer for the steel shell is a different product to what seals the aluminium panels. Apparently corrosion can occur under the paint if you do not use the correct aluminium one. The body shop was not aware of that, it was a paint manufacturer who pointed it out. The car should be painted in a couple of weeks. cheers Lindsay
I believe it is just a self etch primer needed, perhaps Nick W could comment.
Nick W
Post by Nick W »
Yes I use etch primer,... thing I find with aluminium, it it can be contaminated very easily, After sanding it need primer on straight away, as is oxidise quickly. Best way to ensure a perfect key for the primer is to carefully blast clean the alloy, obviously at a low pressure/ fine glass bead . I handle it with gloves on once it's ready for primer, as sweat will mark it, causing problems months after its painted.
850south
Post by 850south »
is this the Magnum one at Minispares? MS114ALLOY - ALUMINIUM BONNET SKIN (NO LIP) ...and what do they mean by No Lip?!
imack
Post by imack »
850south wrote: Thu Sep 08, 2022 6:10 am is this the Magnum one at Minispares? MS114ALLOY - ALUMINIUM BONNET SKIN (NO LIP) ...and what do they mean by No Lip?!
No mk2 type lip on the front edge to mount the chrome trim.
And it's the same panel. Made by Magnum & sold by Minispares amongst others.
850south
Post by 850south »
Thank you! Slow on the reply, but I did purchase one:)
