MPI
Has thanked: 262 times
Been thanked: 231 times
Re: MPI
TMF has a technical forum section dedicated to the injection Minis which might also be worth searching through the topics for similar MPi issues:-
Problems, Questions and Technical → Injection Mini Specific - SPi/MPi :-
https://www.theminiforum.co.uk/forums/f ... ic-spimpi/
hanlminiman
Has thanked: 21 times
Been thanked: 37 times
Re: MPI
Post by hanlminiman »
Thank you Peter.
What I didn't mention was the ECU problem I encountered on the way to the start of the 2006 Lombard Rally. Never did identify the source of the problem but car does run well now. Still clad with Lombard 2006 rally plates etc and the regulation Colway rally tyres and wheels for shows.
ps Spares now include ECUs, engine management loom and all sensors and the car was recommissioned this year and starts onn the button but I do disconnect the battery while in storage.
Darrenfive0
Re: MPI
Post by Darrenfive0 »
hanlminiman wrote: Sun Aug 20, 2023 5:26 pm Check that all the earth points on the car are excellent and also make sure the 2 multi plug connectors to the ECU have clean connections. Also check that no engine loom wires are chafing. Many years ago the AA identified that my loom was chafing against the clutch master cylinder and effected a temporary repair by adding rubber breather hose around the source. It's still there and I haven't had any problems from that since.
Ok Thanks I’ll give that coat of looking at. Cheers
Darrenfive0
Re: MPI
mab01uk wrote: Sun Aug 20, 2023 6:55 pm TMF has a technical forum section dedicated to the injection Minis which might also be worth searching through the topics for similar MPi issues:-
Cheers 👍
