Any Old Iron!
MiNiKiN
Has thanked: 95 times
Been thanked: 31 times
Re: Any Old Iron!
Post by MiNiKiN »
Exminiman wrote: Sat Jan 28, 2023 7:27 am To be fair the seller was open about the issues, what a price, lucky seller
Makes you wonder what caused the issue, could it really be over tightening on a stud ?
Oil in the blind hole. Once you tighten it up the hydraulic pressure cracks the material. My best guess on the cause...
timmy201
Been thanked: 42 times
Re: Any Old Iron!
Post by timmy201 »
I'd think because both stud holes are cracked the same direction it would more likely be due to a drop/impact while the cap/studs were installed.
Re: Any Old Iron!
timmy201 wrote: Mon Jan 30, 2023 8:36 am I'd think because both stud holes are cracked the same direction it would more likely be due to a drop/impact when the cap/studs were installed.
That was my guess too.
I was not criticising the seller, he was perfectly honest about the damage. I do wonder about the bidders though.
Costafortune
Has thanked: 36 times
Been thanked: 38 times
Re: Any Old Iron!
Post by Costafortune »
As soon as you can buy all this stuff new again at a reasonable price, particularly cranks (most of which were scrap 30 years ago) then the price of all this stuff will drop to what it should be, i.e 50 quid and a Twix.
All these blocks, cracked, milled, bodged, bored and sleeved to buggery, cranks ground to 50 thou and probably full of cracks - just door stops depriving a foundry of a decent feed.
Hipwell
Re: Any Old Iron!
Post by Hipwell »
FWIW, Those on Instagram, (probably not many lol), KAD repaired this (or what looks much the same failure) on another S block this week.
Theres numerous pics/videos, midway screengrab.
Re: Any Old Iron!
A job well done, but at what cost?
https://www.instagram.com/p/CoIkp9QoGw7/
360gts
Been thanked: 61 times
Re: Any Old Iron!
Post by 360gts »
Sometimes it is worth paying the $$ when you get such incredibly professional work. You can drive home with a smile on your face knowing that you got what you paid for.
Hats off to British engineering once again. Compare that to the sort of crap work that I have seen here in Western Canada.....to rub salt in the wound is the cavalier attitude and the ridiculous prices that we are subjected to.
That is a beautiful piece of workmanship......would love to have that option here.
Re: Any Old Iron!
I bet the cost was twice that of a decent second hand block though.
360gts
Re: Any Old Iron!
Post by 360gts »
mk1 wrote: Thu Feb 02, 2023 4:11 pm I bet the cost was twice that of a decent second hand block though.
Could be Mark, but the point is....maybe the owner wanted to retain that block...maybe the date etc. was important....
As I said.....sometimes it is worth paying for top workmanship.
I would trade our crap for that any day. Just my opinion.
Exminiman
Has thanked: 58 times
Been thanked: 57 times
Re: Any Old Iron!
Post by Exminiman »
Sort of raises the question, about the MS block and what date code would it have.
Probably not practical, but would be good if you could choose date code you wanted :o
Closer to the original block the better in my view
I can understand someone wanting to keep original block that came with car, but other than that, a replacement block is just another block with a date code that's close.....from another car.
Re: Any Old Iron!
That ain't going to happen, is it. How could you order a date coded block when the numbers are cast into it, it would mean them being cast to order. .
Exminiman
Re: Any Old Iron!
Post by Exminiman »
mk1 wrote: Fri Feb 03, 2023 8:08 am
That ain't going to happen, is it. How could you order a date coded block when the numbers are cast into it, it would mean them being cast to order. As with all stuff like this 90+ % will be going to Racers who don't give a stuff about things like this.
Guessed as much, Just thought would be icing on the cake.....cant be beyond the wit of man....
Re: Any Old Iron!
The only way that anyone can get costs down on a project like this is by casting a large number of blocks in one go & machining them in the same way. Invariably there is as much cost in setting up as there is in machining time. Doing a large number together amortises the set up cost over a large number of items. Doing them individually would push the price up exponentially. I doubt that anyone would want to swallow the cost of a date coded block, even if someone was prepared to do them.
Costafortune
Re: Any Old Iron!
Imagine talking about date coded blocks 40 or 50 years ago. :lol:
Re: Any Old Iron!
Costafortune wrote: Fri Feb 03, 2023 3:54 pm Imagine talking about date coded blocks 40 or 50 years ago. :lol:
Indeed :lol: :lol:
mk1coopers
Re: Any Old Iron!
Post by mk1coopers »
Just 3D print a date code, stick it to the block, paint over it ?
251 ENG
Re: Any Old Iron!
Post by 251 ENG »
Historic race cars haven't had to use cooper s blocks for years .
I think they would be very limited demand for new blocks for appendix K 1293 race engines
Formula Juniors have to use blocks with tappet chest covers but technically they should be AEG 151 thin flange ones
bubbacluby
Re: Any Old Iron!
Post by bubbacluby »
Exminiman wrote: Fri Feb 03, 2023 7:45 am Sort of raises the question, about the MS block and what date code would it have.
What are Minispares up to with their recast a-series blocks?
I haven't seen or heard anything about them since IMM60?
Exminiman
Re: Any Old Iron!
Post by Exminiman »
Phoned them up last week to ask the question, transferred to someone “ who would know”.was told maybe by end of this year, more likely early next….still some testing to do though. If anyone knows any more please do chime in
Exminiman
Re: Any Old Iron!
Post by Exminiman »
mk1coopers wrote: Fri Feb 03, 2023 5:37 pm Just 3D print a date code, stick it to the block, paint over it ?
Thats all I could think of, maybe in aluminium……..possible factory option or kit, for those who need it or want it….
Had my tongue firmly in my cheek when I suggested it though ……
