Lucas ranger spot/reverse lamp
Paulk7364
Post by Paulk7364 »
Can you change the bulb to a LED bulb ?????
Has thanked: 150 times
Been thanked: 137 times
Re: Lucas ranger spot/reverse lamp
You can but you won't get a 'spot' from the spotlight part because the focal length of the bulb in relation to the reflector is all wrong. Just the usual blinding white light! Mind you, perfect for a reverse........ BUT! The brightness exceeds that permitted - unless you can dim it a bit.
Paulk7364
Post by Paulk7364 »
Thanks for the reply
It is actually for a reverse lamp
Do you know the correct led bulb to purchase ?
I've got no idea....... but I bet you that someone the forum will know!
Paulk7364
Post by Paulk7364 »
Ok thank you anyway
snoopy64
Has thanked: 93 times
Been thanked: 14 times
Post by snoopy64 »
Call the guys at Classiccarleds…they are very helpful…
Kevin
Paulk7364
Post by Paulk7364 »
Ok will do thank you
