When I owned SCV Kev I put a set of these Minilites on it to see if they'd fit (before I put the D1s on it), they had Yoko A008s on which rubbed on the radius arms very slightly at the back.
MiniSpares minilites
- WMU 211G
Re: MiniSpares minilites
1992 Maserati Biturbo 430 2.8 litre V6
- snoopy64
The insides are the main giveaway- my old original magnesium ones have the thinner outer rim, but I also have a thick rim one here somewhere.
Direct comparison as requested
- WMU 211G
Std 998 Cooper.
Is Tim having those lovely Cosmics back off you then...?
- snoopy64
Ok, no prbs.... I have the spacered drums on the rear now.... Tim can only dream
Kevin
Kevin
- Maddog
I'm using Dunlop R7s on mine and they provide a bit of cheeky poke on a standard Mk1 shell with S discs and spacer rear drums. Probably not quite legal, but looks great.
Interestingly, looking at the comparison photos from Andypen, the later version of the Minispares ST wheel has a different casting profile on the back face. However, I have seen photos of the back face of the earlier Minispares Minilife wheel that has exactly the same casting rib pattern as the genuine original Minilite. These would be almost indistinguishable from a period Minilite aside from the composition (alloy vs mag-alloy).
As others have said, and I agree, they are great rims, especially if you can't justify the expense of the MS Rosepetals, which would be maybe my other choice if I won the lotto.
Minispares Rosepetals are 4.75" I don't think the Minispares "ST" type Minilite wheel is.
General dogsbody.
General dogsbody.
- coopertim
- Location: In the garage spending far more time and money than my wife agreed to! Lincolnshire UK
The Minispares Minilites are definitely 4.5s and so are the Japanese CR Rosepetals which is why they look fantastic with the Blockley 145 tyres.
Later Minilifes and 145 Blockley’s on my 997 (S brakes on the front). I like the skinnier look of the 145’s…
- snoopy64
