Facebook tries to restart as outage continues into fifth hour...
A section dedicated to non Mini related conversations that some members may find disturbing, worrying or offensive. If you are likely to be troubled by non Classic car related content, I would suggest you avoid!
"WhatsApp, Instagram and Facebook have all gone down in a major outage. The three apps – which are all owned by Facebook, and run on shared infrastructure – stopped working shortly before 5pm. Other related products, such as Facebook Messenger and Workplace, have also stopped working.
At time of writing, it is unclear what has caused the issue...."
"There are rumours whipping around the internet that, among other things, Facebook has been “deleted”, that it has been “hacked”, that is has “gone”. The truth appears to be a little less dramatic – though still plenty dramatic.
Essentially, Facebook has deleted its DNS, or the address book that helps people find its websites. When someone types “Facebook.com” into a web browser, the DNS should be able to provide it with the numerical address to get the data that represents the website. But that DNS is broken, so the web browser gets lost, and you get an error message. (The same thing happens, effectively, with the app, although not in such an obvious way.)
That’s so widespread because Facebook controls its DNS. And Facebook does that on behalf of all the services it owns: WhatsApp, Instagram, Messenger, Workplace, Oculus, and more besides. So everything has broken, all at once.
What’s more, Facebook also heavily relies on its own systems internally. So, for example, the fact the DNS isn’t working means that those engineers who should be able to fix it also can’t access it. That’s why staffers are now reportedly being sent to actual physical data centres to try and make things work again. And that’s where we are now.
To borrow an analogy from earlier, it is as if we (or our web browsers) have turned up at the Facebook office in the hope of getting into one of its many rooms. But the receptionist who usually keeps the record of which room is which is gone – they’ve been deleted – and so you’re stuck outside with no idea where to go.
Inside those rooms are not only Facebook but every Facebook property, which together makes up much of the internet. And all the people who would normally be able to hire a new receptionist can’t find their way around the building, too. We’re all stuck outside, looking in, even those people who would normally be on the inside.
It’s now been five hours since Facebook lost its receptionist. And there’s no sense when they’ll return.
This latest outage of WhatsApp, Instagram and Facebook (including Facebook Messenger and Facebook Workplace) highlights that global outages are one of the major downsides of a centralised system. Centralised apps, like having a single back end for Facebook products, means putting 'all the eggs in one basket.' Decentralised systems are far more reliable. There's no single point of failure so they can withstand significant disruption and still keep people and businesses communicating."
Twitter slows down.
"Everything is having a bit of trouble, presumably as many more people than usual switch to it to make up for lack of Facebook. Like Telegram, Twitter is struggling."
https://www.independent.co.uk/life-styl ... 32071.html
I always said forums were better.... :lol:
