A different pain. 2018 jeep compass.
The Home of any non Mini projects & discussion.
Joel Welsh 4769VU
Post by Joel Welsh 4769VU »
I'm constantly amazed working on my cooper...
Even though she's been through a restore by a PO, for a 60 year old car- I've only had one siezed bolt that would not come loose.
Today, i had to replace an oil pan on my jeep compass SUV. Already kind of sore about the fact that i had to- because it was leaking due to rusted pinholes in the metal. At 5yrs old! Seriously... :shock:
Well, it certainly was not the same joy that i get working on Dianna, i can tell you that.
I just want to know- who was the genius that decided to engineer an exhaust mount bracket at the base of the manifold... that covered the bolt for the oil pan? I wound up cutting the exhaust bolts off with an angle grinder to remove the bracket. Then i had to further cut them, and drill them out- as the studs were siezed in the pipe. Replaced with stainless nuts and bolts.
Something that should have been a relatively straightforward job... became a tedious mess.
Every mechanic knows that exhaust bolts rust, corrode, and sieze up. Why the heck would you put them this way?
4-5 hours to complete the mission. Ugh.
Wauseon, Ohio- United States
Tartan red and black
I can't take credit for what others built- all I can do is try to put her back on the road. :shock:
You just can't fix stupid... you can hide it sometimes though... :lol:
Exminiman
Re: A different pain. 2018 jeep compass.
Post by Exminiman »
The barcode sticker has outlasted the oil pan (sump) , thats bad…… :lol:
Some companies/manufacturers will pay you if yoiu submit a good idea to their R&D people. I got £50 some years ago from a motor mower manufacyurer. Just for suggesting that if they put elongated slots in a metal cover instead of holes. You could remove the cover without having to take the bolts out. Just loosen the 3 bolts and slide cover out - and in!
I reckon my Jeep is less rusty than that & it 80 years old this year :lol: :lol:
It does drop a bit of oil though :)
woodypup59
Post by woodypup59 »
Just beware the stainless trap.
Stainless bolts are more prone to seizing than mild steel. OK they don't rust, but push the rust somewhere else.
The mini exhaust manifold set up is the ideal - steel studs and brass nuts
I too have never been a great fan of stainless fasteners. S/S is more brittle than traditional high tensile so if it does get stuck, you are far more likely to wind the head off.
63monte
Post by 63monte »
Quick tip: if you are going to use stainless fasteners of any kind always,always, always smear with copper slip. It should prevent seizing, it has for me …….. so far :P
Joel Welsh 4769VU
mk1 wrote: Mon Feb 20, 2023 10:59 am I too have never been a great fan of stainless fasteners. S/S is more brittle than traditional high tensile so if it does get stuck, you are far more likely to wind the head off.
Myself either... but the only place that had them on hand, closer than 30 miles, was a hardware store.
It was either stainless, or galvanized.
Figured they were the least problematic for the now? :? :D
Stainless fasteners. Chaps........ with our level of vibration and torque settings, be rest assured that all is well with stainless steel fixings as supplied by the good commercial outlets. If they're good enough on tank gun platforms................
I'm not a metallurgist per-se Woody, but I don't understand the physics of stainless just pushing the corrosion elsewhere. It doesn't work in any sort of sacrificial way that's for sure. Coppaslip....., always a good idea I say, especially if it gets hot
woodypup59
Put simply Peter, the chromium and nickel in stainless makes it more noble than plain steel, which makes the plain steel sacrificial.
If you use zinc plated nuts on plain steel, they are the sacrificial part.
But I'm sure that MIL grade stainless is better than B&Q s/s cheese.
