1991 Cooper Mainstream Project
The Home of any non Mini projects & discussion.
mini_surfari
Re: 1991 Cooper Mainstream Project
Post by mini_surfari »
Thanks Peter!
A bit of progress again, the old mans been hard at it, prepping the engine bay and boot for paint, and refitting parts over the last couple of weeks.
We're running out of space a bit, so we're going to get this car one rolling, and then make a start on the outside, hoping we can blend the old paint with the new.... not sure it'll work yet.
Next job, repair the rear subframe since we received a nice little package from Peter Laidler!
mini_surfari
Well, thanks to the forums Peter Ladler, we managed to repair the subframe in the best way possible.
He turned up these nuts to locate in the original holes for the radius arm bracket.
Cap head bolts have been used as it easier to them in past the arm personally.
And finally gave it a good going over with the wire wheel (after the sandblaster made such a shit job of it). The old man gave it a few coats of paint, and in it went.
mini_surfari
The cars back rolling!
Now the predicament, do we try and blend the repair areas, or paint the whole outside? Any experience body guys want to chuck their 2 pence in?
I'm not a body man but I'd give it a total re-spray, The other body sections look like they are pretty good and will just need a fine sanding/smoothing followed by a quick blow job of colour onto the already sound base. Is it Saturn Red? Nice colour but being red......., what with age, sunlight and pigment I bet that it'll be a real pig to blend even though there are plenty of panel lines to help.
AndyPen
Post by AndyPen »
Agree on the red discolouring, I'd side with Peter and I am sure you'll appreciate all the hard work later ;-)
