Moulton Bike tec question
The Home of any non Mini projects & discussion.
Polarsilver
Post by Polarsilver »
Restoring 1965 year Moulton F Frame Bike and the rear Rubber suspension pad has separated from its steel bonded mounting plate .. This Part is not available new or used & the Molton Guru has departed .. so i need to re-bond this oblong Rubber Block back onto its original Steel mounting Plate ..until a nos pad turns up somewhere.. Question what type Glue would be suitable when re-making a Rubber to Steel Bonding ?
When the Bike is back in action this Rubber Pad rear suspension block is working in compression & shear.. so i suspect a 56 year old rubber component re=bond to its original steel plate will not be very good or reliable .. but got to try something any suggestions. ?
olddave
Re: Moulton Bike tec question
Post by olddave »
Windscreen bonding adhesive?
Something like Tiger Seal or Sikkaflex will work perfectly. Very similar to the windscreen bonding stuff suggested above.
General dogsbody.
GTM71
Post by GTM71 »
I would go with tiger seal, its incredible stuff!
I restored a 64 Moulton several years ago, have the parts for another in my workshop, I will have a look if the rubber block is still there.
I'd be happy to sell it to you.
One think to bear in mind its to make sure you weld in a stiffener to the rear trailing arm, they are very weak on the earlier bikes.
Simon
GTM71
Post by GTM71 »
This is a good resource of how to do it amongst other things
https://www.bicyclehub.co.uk/strengthen-rear-forks
CT1 might also be worth a try:-
https://www.ct1.com/our-products/ct1/
(Available from Wickes and Toolstation).
I sell both CT1 & Tigerseal.
I'd certainly use Tigerseal over CT1 on that job.
General dogsbody.
5portsrock
Post by 5portsrock »
3m 847 contact adhesive
Bitsilly
Post by Bitsilly »
Tiger seal, in black.
