1972 innocenti T 1000
The Home of any non Mini projects & discussion.
colonel mustard
Re: 1972 innocenti T 1000
Post by colonel mustard »
A few more jobs done, thanks to Andrew for the rear Girling estate shocks, cleaned up well.
colonel mustard
A finally the pedal box overhauled with the original felt pad installed
colonel mustard wrote: Sat Jan 08, 2022 5:30 pm
After trying a couple of paints I found that led an paint used on radio controlled cars was just the ticked, as this has to be used on the inside of the plastic moulded shell so the colours are correct when looking on the outside.
What brand of paint did you use because that finish is excellent?
colonel mustard
Thanks Stu
It was The ultimate chrome, I could only get it for America as all uk distributors had no stock, and still have not!
https://supergdrift.com/store/product/u ... spaz-stix/
Thanks for the info. I might give it a go on my Mk3 Inno bonnet badge.
AndyB72
Post by AndyB72 »
Nice bit of progress, great work on those lights!
colonel mustard
Not much progress over the last few months due to work commitments.
Should hopefully have the rear wheels on over the coming weeks then onto the front subframe etc…
Whilst I wait for parts and cash flow I started to drag out the engine and strip down.
The engine looks like a standard 998 pre a+ block, the cylinder head is 12A1456sm - is this correct for a 73 Innocenti t? Anyone know much about this head?
MiNiKiN
Post by MiNiKiN »
colonel mustard wrote: Thu Jun 09, 2022 9:41 pm Whilst I wait for parts and cash flow I started to drag out the engine and strip down.
I would have thought in '72 they had used a Innocenti 1001 engine with the 12G295 head - so this head with the valve spring clips on your engine does not seem right to me (wheren't these a much older design from the very early model years of the Mini)
If only I knew the power of the Dark Side...I wouldn't have made contact with an Innocenti :mrgreen:
robert_stryk
Post by robert_stryk »
To my knowledge the van did not benefit from the saloon engine, and if I recall the advertisements correctly has a lower HP number mentioned. So the head could be correct.
MiNiKiN
Post by MiNiKiN »
You may check and translate the data on miniminor.com (except the capacity figure, which is wrong there) and best ask Lorenzo himself. He is very helpful and knowledgeable with regards to everything Innocewnti
https://www.miniminor.com/scheda-tecnic ... ni-t-1000/
