1972 innocenti T 1000
The Home of any non Mini projects & discussion.
colonel mustard
Re: 1972 innocenti T 1000
Post by colonel mustard »
Hi Andy
Yes the roof will be repainted but for now it sits under a dust sheet to stop the cream seats clashing :shock:
Have not paid any attention to the engine and is sits under the work bench currently, covered in years of grit, grime and wood shavings! Will have a look early next year.
Not had much time recently and it’s been left with one last bolt to be installed on the rear sub frame, hopefully have a bit more time nearer Christmas!
Also started to strip radius arms down and other bits ready for painting.
The rear lights are hard to come by and the chrome inner paint was quite badly flaking. Managed to blow the chrome paint off and re-sprayed in a lexan paint. Result we’re not bad considering the plastic is showing a few stress marks. Also refurbished the wiper motor.
colonel mustard
A few more updated photographs
All glass now installed, with the exception of the front screen.
Chrome strip down run down the panels all lined through, re drilled and clipped on in place
AndyB72
Post by AndyB72 »
Looks fantastic! Do you have the steering wheel horn push for it, I think I have a few in the garage. Should it be the 'i' logo?
colonel mustard
Hi Andy
I think so, will have to check.
I am missing the side light / repeaters if you have any of those lying around!
Also on your innocenti with the rubber matts, how far did you go with the sound proofing under felt?
AndyB72
Post by AndyB72 »
I've no repeaters sorry. From what I remember I just put some felt into the recesses in the front footwells to bring the level back up and some behind the heater and inner wheel arches. Do you have the plastic strips that fix the rear rear floors for the seats to sit and run on?
rpb203
Post by rpb203 »
Do you have a picture of what the repeaters looks like?
Are they round or a different shape?
rpb203
Post by rpb203 »
Ahh just seen they are round on the front page.
So can’t help - sorry.
colonel mustard
Thanks both
Andy, yes I believe i have some black plastic skids, now I know what they are! :idea:
colonel mustard
It’s been a slow few months, what with COVID and manic workload at work.
A few jobs that I have tinkered with have been:
Overhauling the rear, very rare, carello rear light lenses. The chrome effect paint had flaked off and was looking rather tatty. After a bit of trial and error, the air compressor was the tool to blow the flaky paint off and prepare the plastic. The problem with most chrome effect paints, which there quite a few, are there are meant to be used as the finished topcoat but unfortunately in this scenario it had to be used on the inside and have the finish showing through the plastic.
After trying a couple of paints I found that led an paint used on radio controlled cars was just the ticked, as this has to be used on the inside of the plastic moulded shell so the colours are correct when looking on the outside.
colonel mustard
The finished lenses
